    ARGON 1 Cooler control script
    argon control cooler script
    3270
    • mkoff
      mkoff last edited by mkoff
      Hi. There is no way to run the script over SSH. Maybe there is some other way to connect it?
      curl https://download.argon40.com/argon1.sh | bash
      dstroy 1 Reply Last reply Reply Quote 0
      • dstroy
        dstroy @mkoff last edited by
        @mkoff
        There is no way cause it's not the right script get this one :
        curl https://download.argon40.com/argonone-setup-recalbox.sh | bash
        yours is for raspbian oses like.
        • Pitch64
          Pitch64 Staff last edited by
          To complete the answer for anyone else, ssh to your rpi4 and copy the command from @dstroy's post. This will install all the necessary to have the fan and shutdown to work. I did it and works fine. I just had to reinstall it after the upgrade from 7.0.0 to 7.0.1 to have it working back, but it's a small issue and needs to be confirmed if others got it too 🙂
          Next release? Soonâ„¢
          • mkoff
            I want to test the script. How can you load Recalbox 7 to raise the temperature above 55 degrees?
            • mkoff
              Its Working. Heated with Dreamcast "Exhibition of speed" + Warm cloth on top 🙂
              • Secamfr
                Secamfr last edited by
                @mkoff You can edit parameters in this file :
                /share/system/argononed.conf
                mkoff dstroy 2 Replies Last reply Reply Quote 1
                • mkoff
                  mkoff @Secamfr last edited by
                  @Secamfr
                  I found this. Thanks!
                  • dstroy
                    dstroy @Secamfr last edited by dstroy
                    @Secamfr
                    if you are not used to vim/vim or other nix editor you can use an interactive config command via typing
                    argonone-config in your terminal after getting on pi via ssh after having installed & run the install script
