    [Recalbox 7.0.1] es_systems.cfg file does not exist! / Hide some extensions file
    [recalbox 7.0.1] essystems.cfg file does exist hide extensions
    • Adrian Nawrocki
      Adrian Nawrocki last edited by
      Hello,
      I have one problem. I wanted to hide the detection of some file extensions on cores.
      Example:
      On X68000 i have .dim (like bin) and .m3u (like .cue file on psx).
      I want to hide .dim file
      On Amiga CD i have .cue and .iso and i want to hide .iso file
      In Recalbox 5-6.x.x it was very simple. It was enough to edit the file:
      /recalbox/share/system/.emulationstation/es_systems.cfg
      In Recalbox 4.x.x file:
      /etc/emulationstation/es_systems.cfg
      In Recalbox 7.0.1 this file is not exist! It even shows an error related to it in the system logs. Last log.
      [1980/01/01 02:00:12.953] (INFO ) : Creating surface...
      [1980/01/01 02:00:13.097] (INFO ) : Created window successfully.
      [1980/01/01 02:00:13.135] (INFO ) : Activating vertical sync'
      [1980/01/01 02:00:13.135] (INFO ) : Normal VSync' activated.
      [1980/01/01 02:00:13.842] (INFO ) : ViewController instance created.
      [1980/01/01 02:00:14.157] (INFO ) : Checking available OpenGL extensions...
      [1980/01/01 02:00:14.158] (INFO ) :  ARB_texture_non_power_of_two: MISSING
      [1980/01/01 02:00:14.160] (INFO ) : Loaded 11 configuration entries for device Keyboard
      [1980/01/01 02:00:14.639] (INFO ) : SDL AUDIO Initialized
      [1980/01/01 02:00:14.695] (WARN!) : /recalbox/share/system/.emulationstation/es_systems.cfg file does not exist!
      And here comes the question. How do I hide some extensions file?
      Just don't tell me to hide it from the menu. I have several thousand roms and it would take me forever to hide them.
      Best,
      Adrian
        @Adrian-Nawrocki said in [Recalbox 7.0.1] es_systems.cfg file does not exist! / Hide some extensions file:
        /recalbox/share_int/system/.emulationstation/es_systems.cfg
        • Adrian Nawrocki
          No es_systems.cfg file on internal and external .emulationstation folder 😕
          i tried copy es_systems.cfg from /etc/emulationstation, but no results
            Zing Global moderator Translator @Adrian Nawrocki last edited by
            @Adrian-Nawrocki
            Isn't it easier for you to hide these files from your gamelist?
            Skraper can do this for you, see this tutorial (enable subtitles):
            https://www.youtube.com/watch?v=G388Gc6kkRs&list=PL2oNQ0AT7fx2ExiSNrfHUzga5GnogI4sh&index=22&ab_channel=Recalbox
            This part about hiding some types of files is mentioned as of 06:25.
            Or, if you prefer, you can use ARRM:
            https://forum.recalbox.com/topic/11850/arrm-another-recalbox-roms-manager
            nexusone13 1 Reply Last reply Reply Quote 0
            • nexusone13
              nexusone13 @Zing last edited by
              @Zing said in [Recalbox 7.0.1] es_systems.cfg file does not exist! / Hide some extensions file:
              @Adrian-Nawrocki
              Here is the corresponding topic in ARRM Wiki : http://jujuvincebros.fr/wiki/arrm/doku.php?id=remove_extensions_gamelist_en
              ARRM (Another Gamelist, Roms manager, and Scraper for Recalbox, Batocera, Retropie) : http://jujuvincebros.fr/telechargements2/file/10-arrm-another-recalbox-roms-manager
              Wiki ARRM: http://www.jujuvincebros.fr/wiki/arrm/
              Discord: https://discord.gg/p7QsBTS
