    Overclocking Pi4 with recalbox 7
    overclocking pi4 recalbox
    13
    57
    17393
    • LapinFou
      LapinFou @sergioad last edited by LapinFou
      @sergioad Good point. Indeed I'm running a 4GB version.
      Thanks for the tips.
      EDIT: Why not trying to O/C the GPU at 750MHz ?
      sergioad 1 Reply Last reply Reply Quote 0
      • sergioad
        sergioad @LapinFou last edited by
        @LapinFou I will, thanks for the tip
        • Kruton
          Kruton last edited by
          I am observing really strange behavior when I am applying overclock in Recalbox using Pi 4 4GB and looks like @sergioad report confirms my findings.
          If I set values below in config.txt
          arm_freq=2000
          gpu_freq=750
          over_voltage=6
          then I am getting correct cpu clock when checking back using terminal and framerate especially in PSP games is noticeably better
          # vcgencmd measure_clock arm
          frequency(48)=2000531200
          But if I set maximum allowed Pi 4 OC like this
          arm_freq=2147
          gpu_freq=750
          over_voltage=6
          then I am getting only 600 MHz when checking back using terminal, that is significantly lower cpu clock than stock value and it confirms @sergioad report. Emulation is slow like hell in this case. I am using Pi Case 40 from Cooler Master and temps are below 60°C all time and boosting over_voltage is not helping at all.
          frequency(48)=600169920
          I tried to update to last stable eeprom released 2020-09-03, then applied maximum OC using same method in newly installed Raspberry Pi OS and it was working like charm. Reported clocks were correct and stable. I was testing stability using synthetic load (sysbench) on all 4 cores and temperature did not exceed 65°C after 20 mins of continuous stress testing.
          When I returned back to MicroSD card with Recalbox, then I got same strange behavior when applying max. OC. It looks like overclocking in Recalbox still have some issues and needs some tuning by devs.
          But overall I am really satisfied with this OS. UX is on totally different (better) level compared to for example RetroPie.
          • sergioad
            sergioad last edited by sergioad
            @Kruton I totally agree, Recalbox is superior in UX, easier to manage and overall amazing, and apparently not even a 2100 overclock is safe from this strange behavior, could you confirm?
            BTW the pi case 40 is amazing is not it? I also added the small heatsinks from my kit
            Kruton 1 Reply Last reply Reply Quote 0
            • Kruton
              Kruton @sergioad last edited by Kruton
              @sergioad Yes, I can confirm arm_freq=2100 is not viable too. measure_clock arm is reporting same strange frequency of 600 MHz as 2147 MHz OC for me.
              Pi Case 40 is amazing. Totally passive and well build solution. It has slick power button from factory. Can throw it into my backpack without worries that something broke and play during brakes at work, during party at my friends palace... Just love it, worth of every penny.
              • sergioad
                sergioad @Kruton last edited by
                @Kruton I thought so, I also had issues at 2100, could a higher clock solve the problem? (I am thinking like the higher clocks could act like a save file bypassing a corrupt part of a game rather than a speaker adding noice at higher volume) righ now a pi could easily be overclocked at 2300 (I do not do it for safety) so it is worth the try
                About the case I agree, sadly I could not configure the power button
                • sergioad
                  By the way I am getting some occasional hang-up on ES, I do not know if it has to be with my overclock but it is worth to be shared, that way if the devs can check it they could solve it
                  Support Script
                  • sergioad
                    This post is deleted!
                    • sergioad
                      Ok friends, I fixed my ES hang ups, I dialed back my pi to 1950 MHz and incremented the over voltage to 9 while keeping GPU the same at 750 and this far I have not had any ES hang up.
                      If you want my troubleshooting script package from when ES was failing that much HERE it is.
                      I hope with the findings of the community something could be made to solve the over 2000 issues, I prefer by much Recalbox to the other solutions and not being tied by this bugs would be awesome.
                      Here are my settings:
                      arm_freq=1950
                      gpu_freq=750
                      over_voltage=9
                      rollbrett 1 Reply Last reply Reply Quote 0
                      • rollbrett
                        rollbrett @sergioad last edited by
                        @sergioad i'm not familiar with overclocking the pi 4, but in the documentation i found this about the overvoltage
                        CPU/GPU core voltage adjustment. The value should be in the range [-16, 8] which equates to the range [0.8V, 1.4V] with 0.025V steps. In other words, specifying -16 will give 0.8V as the GPU/core voltage, and specifying 8 will give 1.4V. For defaults see table below. Values above 6 are only allowed when force_turbo is specified: this sets the warranty bit if over_voltage_* is also set.
                        if this is correct, the maximum value of overvoltage is 8?
                        and what about force turbo do you have enable it?
                        SUPERPi CASE-J (new) RPi 3b+ Recalbox
                        MEGAPi CASE RPi 3b Blast16
                        NESPi 4 CASE RPi 4 Recalbox
                        GPi CASE RPi Zero 2 W Recalbox
                        My RetroArchivments
                        • sergioad
                          https://transfer.sh/NZCXK/recalbox-support-d3a5c3b5-7e27-a40d-d23e-2b454077d09e.tar.gz
                          • sergioad
                            sergioad @rollbrett last edited by sergioad
                            @rollbrett no, there are people running pis at over voltage 11, I use 9 on mine because the 8 GB model of the pi needs even more than the usual be 6 because it needs to acomidate the larger amount of RAM, in a 4 or 2 GB model 6 or 7 is more than enough, I have not enabled turbo
                            LapinFou 1 Reply Last reply Reply Quote 0
                            • LapinFou
                              @sergioad said in Overclocking Pi4 with recalbox 7:
                              If you didn't enable the force_turbo, maybe your voltage 9 is seen as a 6?
                              • sergioad
                                @LapinFou Ip sincerely doubt it
                                • Kruton
                                  I did not tested it by myself. But from official documentation and some forum posts by official staff, over_voltage bigger than 6 can be only activated when force_turbo is enabled. It is even possible to go over official limits by using parameter current_limit_override. But you are risking voiding your warranty if anything goes terribly wrong...
                                  Source: https://www.raspberrypi.org/forums/viewtopic.php?f=29&t=6201&start=325#p170793
                                  • deneme
                                    deneme @ian57 last edited by
                                    @ian57 said in Overclocking Pi4 with recalbox 7:
                                    @phimjohn config.txt file only but be very carreful... be sure tu have a good cooling heatsink fan system, because Pi4 heats up a lot.
                                    so whers this config.txt file in recalbox can you help me ???
                                      Zing Global moderator Translator @deneme last edited by
                                      @deneme Please read the topic, this is described a few posts above, you just have to read...
                                      @Zing said in Overclocking Pi4 with recalbox 7:
                                      To edit the config.txt file, you must connect via SSH:
                                      • https://recalbox.gitbook.io/documentation/v/francais/tutoriels/systeme/modification/editer-le-fichier-config.txt
                                      To login via SSH:
                                      • https://recalbox.gitbook.io/documentation/v/francais/tutoriels/systeme/acces/acces-root-via-terminal
                                      • https://recalbox.gitbook.io/documentation/v/francais/tutoriels/systeme/acces/acces-reseau-via-winscp
                                      To access a partition in write mode:
                                      • https://recalbox.gitbook.io/documentation/v/francais/tutoriels/systeme/acces/acceder-a-une-partition-en-ecriture
                                      100.2k
