    Splash videos too big for 7" screen
    splash videos too big
    1954
    • lackyluuk
      Dear Team,
      First of all I want to express my thanks to you for this phenomenal release.
      So far, everything important works for my builds! This is not a matter of course. Thumb up, mates!
      I just got one point for my 7" display (HDMI 4 Pi: 7" Display no Touchscreen 1024x600 with Mini Driver): All splash videos are displayed too big for the screen. So I always see only the middle part of the video.
      After it ended, the screen is displayed correctly (Pac-Man screen, ES loading screen and so on.)
      Is there a fix to also show the splash videos correctly? Do I need to adjust them or is there a setting to be changed?
      Thank you 🙂
      lackyluuk
      • lackyluuk
        Sorry, I forgot to mention my hardware:
        • Board: RPi 3B+
        ian57 2 Replies Last reply Reply Quote 0
        • ian57
          ian57 Staff @lackyluuk last edited by
          @lackyluuk some users reported this too... We are going to check and try to adapt video to screen. Thanks for reporting.
          • ian57
            ian57 Staff @lackyluuk last edited by ian57
            @lackyluuk the /etc/init.d/S06splash script is based on the height of the framebuffer to display the video.
            # cut -d, -f2 /sys/class/graphics/fb0/virtual_size
            1024
            On my 4/3 1280x1024 screen the videos are well displayed. But as the videos are natively in 1920x1080, there are black stripes at the top and bottom.
            As your resolution is not standard, the value returned by the function must not be good.
            Try to add the following configuration at the end of the /boot/config.txt file to tune your own resolution
            disable_overscan=1
            hdmi_group=2
            hdmi_mode=87
            hdmi_cvt=1024 600 3 0 0 0
            Tell me if it is better.
            • lackyluuk
              hi @ian57
              I have just tried your suggestions. Unfortunately if I enable all these options I only have sound but the screen stays black. And the sound is very clippering.
              thanks in advance 🙂
              • ian57
                @lackyluuk ok you can try to add only
                can you give us the full reference of your screen please.
                and what does the following command give on your RB without any modification of config.txt :
                • lackyluuk
                  lackyluuk Translator last edited by lackyluuk
                  Hi @ian57
                  When I only add this line, the video plays but it is still too large
                  The command gives the following result:
                  480
                  Here is a link to the display I have:
                  https://www.pi-shop.ch/hdmi-4-pi-7-display-no-touchscreen-1024x600-mit-mini-driver
                  • ian57
                    @lackyluuk the vertical resolution detected is not good, you should have 600 instead. I need to check how S06splash display video
                    sorry I missed a parameter in the previous configuration ! a important one : the refresh frequency.
                    please try this
                    # uncomment if hdmi display is not detected and composite is being output
                    hdmi_force_hotplug=1
                    # uncomment to force a specific HDMI mode (here we are forcing 800x480!)
                    hdmi_group=2
                    hdmi_mode=1
                    hdmi_mode=87
                    hdmi_cvt=1024 600 60 3 0 0 0
                    It should work better see here https://learn.adafruit.com/hdmi-uberguide/2300-hdmi-4-pi-7-display-no-touchscreen-1024x600-w-slash-mini-driver the same screen as yours
                    lackyluuk 1 Reply Last reply Reply Quote 0
                    • lackyluuk
                      lackyluuk Translator @ian57 last edited by
                      @ian57 thanks for the adafruit link 🙂
                      I have changed the config accordingly (commented also things like
                       #disable_overscan=1
                       #hdmi_drive=2
                      Now it looks much better, but still the video does not match the video (at least on the sides) exactly. But it is already almost good.
                      ian57 1 Reply Last reply Reply Quote 1
                      • ian57
                        @lackyluuk that's cool, can you post a picture of what goes wrong for splash video please.
                        can you retry the command
                        and put the result.
                        thx
                        • lackyluuk
                          Hi @ian57
                          The command now returns the correct value.
                          600
                          Here you can see a "original" recalbox splash video. This one is worse than others (I use two unofficial ones, which fits a little bit better).
