    Recalbox 6.0 RC3 is released
    recalbox 6.0 rc3 released
    20
    43
    19085
      OyyoDams Staff last edited by
      And hop a last "Release Candidate" version before the stable next week ... Yes yes, the stable finally arrives!
      The changes made by the RC3:
      • Press start/enter to play the current game in demo mode
      • Add PCEngine RB video intro
      • RPI: Add I2C support
      • Use gamecontrollerdb.txt in ScummVM/ResidualVM
      • Wifi: improved storage in case of emergency shutdown
      • Bluetooth: detection of 8bitdo and other pads asking for "0000" pin code improved
      • B*mp mk_arcade_joystick_rpi to hotkeybtn branch to get custom gpio features
      • Sega Mega CD bios updated no handle Genesis plus (picodrive compatible)
      Check here for the rest, you're used to 🙂
      Deiviid Correa 1 Reply Last reply Reply Quote 3
      • xHardcore
        xHardcore last edited by xHardcore
        there has not been a significant change since the Amiga's continue to have the same problems regarding controls
        • Bkg2k
          Bkg2k Staff @xHardcore last edited by
          @xhardcore more information are welcome
          xHardcore 1 Reply Last reply Reply Quote 0
          • xHardcore
            xHardcore @Bkg2k last edited by
            @bkg2k amiga 600 dpad not working, amiga1200 not open, amigacd32 dpad and all buttons not working
            • xHardcore
              when selecting shaders in retroarch, they are not saving, I realized this since version 6.0 RC1
              • irondada
                irondada last edited by
                This post is deleted!
                • lhari84
                  lhari84 last edited by
                  @Bkg2k
                  @OyyoDams
                  Following issues are not solved on my side after upgrading to RC3:
                  • dpad in mame 2003 plus not working (is it a tricky issue or will it be solved till final? i've just migrated all arcade to this core, that's why i'm asking ;))
                  • CRC in gamelist.xml is still messed up with appendix "ath" in the end when changing a game record.
                  Everything else is fine here, looking forward to final 🙂
                  Pi 4:
                  Sony DualShock 4 (2nd gen), 8BitDo Pro 2, 8BitDo SF30 PRO, Retroflag SUPERPi 4 Case, Recalbox 9.0
                  Pi Zero 2W:
                  GPi Case 2W, Recalbox 9.0
                    paradadf Staff @lhari84 last edited by
                    @lhari84 regarding mame2003_plus, have you tried using the left analog stick? As far as I know, mame2003_plus maps analog games differently, which is actually the correct way but causes such behaviour. I believe there is an option to bind controls different in retroarch if you want the old behaviour.
                    lhari84 1 Reply Last reply Reply Quote 0
                    • lhari84
                      lhari84 @paradadf last edited by
                      @paradadf Left analog stick is working, but some games are way better to play with dpad. and was announced as an unsolved bug by @OyyoDams in RC2 release notes, that‘s why i‘m asking.
                      in mame 2003 and fba i recognized that some games, especially racing games, support analog stick only too, but many others both analog and dpad.
                      in mame 2003 plus dpad works in absolutely no game, can this really be normal/wanted behavior?
                      Pi 4:
                      Pi Zero 2W:
                      • MA7FOUTH
                        MA7FOUTH last edited by
                        can you please solve kernal PCI disabe broadcom network card ''43'' plzzzzzzzzzzzzzz there is a patch you can add it to fix it or simply update kernal to 4.19
                        • Bkg2k
                          Bkg2k Staff last edited by
                          Fixed in the Stable release
                          • Fix dpad not working out-of-the-box in Mame2003-plus
                          • Improve pad/keyboard compatibility in Amiberry (Amiga)
                          • Fix Atari 800 .xex files (use uncompressed .xex - zipped files not supported)
                          • Fix string garbage in netplay hashes
                          • Fix key=value with empty value in all config files
                          • xHardcore
                            @Bkg2k @OyyoDams @paradadf
                            Congratulations
                            amazing
                            I apologize to everyone, Amiga 600 and 1200 is working 100%
                            it works the analog I forget like mouse and then both the analogic left, as the dpad function like controls, congratulations for the beautiful work to all the recalbox's team.
                            • darth
                              darth last edited by
                              Can you please fix generic PS3 controls that vibrates forever on Raspberry Pi 3b and b+. When I connect them with the USB cable they can not stop vibrating. I tried with the three different drivers but its the same.
                              Thank you so much.
                              • jleppa
                                jleppa last edited by
                                I'm using Rpi3b+. Yesterday I tried to update from RC2 to RC3 without success. Earlier update from RC1 to RC2 went fine. I believe only change on my end is that now I've set emulationstation options to none on recalbox.conf. Message about new update shows correctly after boot but I haven't found a way to start update. No matter what button I press the message just disappears and goes back to emulation station.
                                • Marcelo Sevla
                                  Marcelo Sevla last edited by
                                  Dear. Sorry about my English. After installing the new version RC3, I can not use the scraper, the moment the system finds the images it tries to save and goes to a black screen, after that I have to reboot the system. Would anyone have a solution?
                                  loak 1 Reply Last reply Reply Quote 0
                                  • loak
                                    loak @Marcelo Sevla last edited by
                                    @marcelo-sevla Hi, Recalbox's Scraper is out until further notice. You have to use an external one as Skraper or arrm, plugging your usb key with roms directly in your computer.
                                    Recalbox last update
                                    • xHardcore
                                      @OyyoDams @paradadf @Bkg2k
                                      SHADERS when selected in the retroarch are not saved
                                      we count on your wonderful work
                                      • Bkg2k
                                        Fixed in the Stable release (Update)
                                        • Fix a crash in internal scraper
                                        • Replaced azerty/qwerty layouts by country's layouts (en, fr, it, es, de, ...)
                                        • Fix cursor going back on top of the list when deleting games
                                        • Fix crash when deleting last game from a system
                                        • Temporary removal of ScreenScraper's scraper until v6.1
                                        • Default theme updated
                                        twh_pi 1 Reply Last reply Reply Quote 5
                                        • twh_pi
                                          twh_pi @Bkg2k last edited by
                                          @bkg2k
                                          Is there any reason why the default global video mode for emulators is CEA 4 HDMI?
                                          This leads on my standard TV setup to some very extreme black borders esp. in Atari2600, Atari7800, Colecovision.
                                          I had to manually switch to CEA 5 HDMI or CEA 16 HDMI in the recalbox.conf
                                          • Bkg2k
                                            The "CEA 4 HDMI" is the default 720p resolution, recommended for all Raspberry Pi.
