    Recalbox 6.0 RC2 is released
    recalbox 6.0 rc2 approaching
    8
    27
    12464
      OyyoDams Staff last edited by OyyoDams
      Hi friends! Recalbox 6.0 RC2 is released!
      Here is what has been fixed since the RC1:
      • Fix default GBA games metadata
      • Fix old core names in recalbox.conf (automatically renamed)
      • Add Ximo controller to pre-configured pads/joyticks
      • Fix missing desmume_libretro.so
      • Fix reicast on XU4/X86
      • Fix virtual gamepad
      • Fix device handling to quit demo mode
      • Fix Kodi not starting with some gamepad
      • Fix retroarch core options not saved
      • Fix AROS bios with CD32
      • Fix Oricutron conflicts between 2nd player joystick and keyboard
      • Fix Dragonrise on Amiga (partially, you still need to HK+B and reset the emulator)
      • Fix descending sorts in gamelists
      • Improve randomness in demo mode
      These issues are NOT FIXED yet:
      • AdvanceMame configuration not saved (need some code rework and appropriate tests)
      • The internal scraper is not reliable (need some heavy code rework)
      And just for information, the incredible "Changelog" of the previous 6.0 RC1:
      • Major system upgrade. See https://github.com/buildroot/buildroot/blob/2018.02.3/CHANGES#L1-L1427 for the full log
      • KODI b*mped to 17.6
      • Raspberry Pi3b+ and CM3 support
      • Joypads management updated, mostly impacting joypads advertising as a complete keyboard. You have to reconfigure your pad if it is acting strangely
      • Preconfigured gamepads file rewritten
      • arcade GPIO driver upgraded: now support I2C and GPIO recopnfiguring from the command line
      • x86 now requires a CPU that can handle at least SSE and SS2
      • x86: add support for newer AMD GPU
      • fix PS3/PS4 pads not working
      • fix kodi configgen
      • b*mp rpi kernel + firmware
      • gpio arcadedriver works again
      • fix bug on bluetooth discover
      • Add Capcom RB video intro
      • B*mp kodi.plugin.video.youtube to 6.3.1
      • Add support for Mayflash GameCube adapter
      • ES: better cyrillic display
      • Add ipega 9055 udev rule
      • New upgrade procedure to prepare for the future
      • ES: fix scraped folders display
      • ES: improve image loading
      • ES: now automatically reboots once the upgrade is ready
      • Atari 8 Bits: Added Atari 800 and Atari 5200 support - Thanks to dubbows!
      • MSX: Fixed Bluemsx core
      • Add 7z file support for many libretro cores
      • Docker build unified
      • "overlays" folder and roms subfolders automatically created
      • Fix bug on bluetooth discover
      • ES: fix pads buttons detection and configuration
      • Fix bluetooth detection on Odroid XU4
      • Update version of Theodore core (now supports TO8, TO8D, TO9, TO9+ and MO5)
      • Add homebrew game Mission: Liftoff (Theodore)
      • Fix BT recovery on XU4
      • advmame: add overlay possibility
      • MAME: Added mame2003-plus libretro core. A MAME078 version with added games support plus many fixes and improvements.
      • PokeMini: Add Pokémon Mini support
      • FreeIntv: Add Mattel Intellivision support
      • FreeChaF: Add Fairchild Channel F support
      • pc98: Add PC-98xx series support
      • Add Atari Jaguar on x86(_64) platforms
      • SNES9X: Add Satellaview and SuFami Turbo as own systems
      • Neo Geo CD: Added support with fbalpha emulator (TruRip ccd/sub/img recommended)
      • B*mp FBA libretro to latest version => Romset 0.2.97.44
      • B*mp AtariST emulator to december 2018 version
      • Add Oric/Atmos emulator (Oricutron, standalone)
      • Add MGT Sam Coupé emulator (Simcoupe, standalone)
      • c2/xu4: enable generic quirks for usb encoders like Xin-Mo
      • B*mp DosBox to revision 4178 (December 2018)
      • Beetle PC-FX: Add NEC PC-FX support (x86, x86_64 and xu4)
      • MAME bios folders: Update hiscore/cheats for all MAME versions (courtesy of olivierdroid92)
      • B*mp 4DO to support threaded DSP emulation & lightgun
      • Activate 4DO package on Rpi3
      • B*mp Amiberry to 2.24 (SDL2). Compatible Odroid XU4.
      • Add Amiga CD32 system
      • Add AROS bios as default Amiga bios (2019 version)
      • Add configuration for static ip addresses on wifi interfaces
      • B*mp ScummVM/ResidualVM (January 2019)
      • B*mp almost all libretro cores
      • Package names updated (catsfc -> snes9x2005, pocketsnes -> snes9x2002, snes9x_next -> snes9x2010, pce -> mednafen_pce_fast, vb -> mednafen_vb, imame -> mame2000, mame2003 as core name instead of mame078, fbalpha instead of fba)
      • Improved log formatting
      • Add Demo Screensaver
      Have fun!
      GustavoLima 1 Reply Last reply Reply Quote 3
      • Bkg2k
        Bkg2k Staff last edited by acris
        Bugs confirmed on RC2:
        • Amiga 600 WHDR are not working (fixed for the final release)
        • Mame2003plus - DPAD is not responsive
        • GustavoLima
          GustavoLima @OyyoDams last edited by GustavoLima
          @oyyodams I have installed Recalbox 6.0 RC2 on Raspberry Pi 3B+ and kodi is not launching, any hints?
            OyyoDams Staff @GustavoLima last edited by
            @gustavolima I've just tested on a fresh install and I can confirm you Kodi works on this version.
            • SeatFreak
              SeatFreak last edited by SeatFreak
              I installed on my Raspberry Pi 3b+ RecalBox 6.0RC1, then upgraded to 6.0RC2, since then Kodi has stopped working. When I start Kodi everything is still normal, but when the Kodi main page comes, the mouse pointer is in the corner on the top left and everything is frozen. I also have the problem that when I start the Raspberry Pi 3b+, not equal to the network is there, must first enable and disable Wi-Fi until then until sometime the WLAN works. Router is FritzBox 7490.
              lhari84 1 Reply Last reply Reply Quote 0
                Hello @SeatFreak
                Have you reconfigure gamepad ?
                • SeatFreak
                  Hello acris
                  No, I did not have that. Do I have to do this after every update?
                  Thanks for the tip, I tried it right away.
                  Kodi works now again, after reconfigure the Gamepad.
                  many thanks.
                  • lhari84
                    lhari84 @SeatFreak last edited by lhari84
                    @seatfreak said in Recalbox 6.0 RC2 is released:
                    Regarding wifi, set wifi region to DE in recalbox.conf (or FR, or AT; just something european, instead of US).
                    Also had same issue with my FritzBox. I can‘t understand why this is set to US by default. A developer told me it‘s to be complient in US, because they use less channels/frequecies. But many users have these problems and don‘t know what to do. I would set European setting as default, as it‘s European software. If US citizens use it, they can change if necessary. Just my point of view...
                    Pi 4:
                    Sony DualShock 4 (2nd gen), 8BitDo Pro 2, 8BitDo SF30 PRO, Retroflag SUPERPi 4 Case, Recalbox 9.0
                    Pi Zero 2W:
                    GPi Case 2W, Recalbox 9.0
                    • SeatFreak
                      Yesterday I followed the tip to reconfigure the controller then Kodi went again,
                      but after a recalbox restart and game list update in the options,
                      after Kodi was frozen again.
                      • lhari84
                        lhari84 last edited by
                        @OyyoDams Hi, since version 6.0 I got some warnings about invalid CRC in es_log.txt. No big deal, but would be interesting where these come from. Examples:
                        [2019/04/03 00:31:48.413] (WARN!) : Invalid CRC32 FD7B1BE33ath
                        [2019/04/03 00:31:48.414] (WARN!) : Invalid CRC32 FE43FE586ath
                        [2019/04/03 00:31:48.414] (WARN!) : Invalid CRC32 02FAD2B66ath
                        [2019/04/03 00:31:48.415] (WARN!) : Invalid CRC32 FA8DF0BA3ath
                        [2019/04/03 00:31:48.415] (WARN!) : Invalid CRC32 FF9ED9819ath
                        Thanks for all the work you guys do, version 6.0 RC2 is working very well here on Pi3 B+!
                        Pi 4:
                        Pi Zero 2W:
                        Bkg2k lhari84 2 Replies Last reply Reply Quote 0
                        • Bkg2k
                          Bkg2k Staff @lhari84 last edited by
                          @lhari84 check the corresponding gamelist.xml file.
                          What did you use to generate those CRC? An external scraper? The internal ES tool?
                          • lhari84
                            lhari84 @Bkg2k last edited by
                            @bkg2k Hi, I used external scraping tool (Skraper). Afterwards I run internal solution in netplay-section.
                            Pi 4:
                            Pi Zero 2W:
                            • lhari84
                              lhari84 last edited by lhari84
                              I want to report another minor issue:
                              I wanted to compress pcengine and sega cd roms (bin/cue) and used a tool named chdman to create chd-files.
                              Now pcengine is working fine with those chd-files, but sega cd only runs into a black screen for about 10 seconds and quits to ES then. (Of course i tried the old bin/cue rom before compression and it worked too)
                              I used tool version from this manual. Maybe I have to use another version? Or is it a bug in sega cd's chd support?
                              https://www.reddit.com/r/RetroPie/comments/72kh6q/stepbystep_guide_how_to_convert_sega_cd_or_pc/
                              (I know it's a manual for retropie, but I guess emulator is the same and for pcengine it appearantly works in recalbox)
                              Pi 4:
                              Pi Zero 2W:
                              • lhari84
                                Three more findings:
                                recalbox.conf
                                I have already read about from other user during beta phase and don't know if it should be fixed in meanwhile:
                                When enabling (uncommenting) power/reset switches on Pi 3B+' GPIO, in my case line with "PIN356ONOFFRESET", the same entry appears many times (all uncommented) in recalbox.conf. Seems that all other (still commented) entries are replaced by any reason:
                                ------------ A - System Options -----------
                                Uncomment the system.power.switch you use
                                system.power.switch=PIN356ONOFFRESET # https://github.com/recalbox/recalbox-os/wiki/Add-a-start-stop-button-to-your-recalbox-(EN)
                                es_log.txt
                                Here appears an error saying config file missing. + systems are listed double-named like "3do3do".
                                2019/04/04 00:20:15.340] (ERROR) : /recalbox/share/system/.emulationstation/es_systems.cfg file does not exist!
                                [2019/04/04 00:20:15.340] (INFO ) : Loading system config files /recalbox/share_init/system/.emulationstation/es_systems.cfg...
                                [2019/04/04 00:20:15.349] (WARN!) : Key: 3do3do
                                [2019/04/04 00:20:15.350] (WARN!) : Key: amiga1200amiga
                                [2019/04/04 00:20:15.350] (WARN!) : Key: amiga600amiga
                                [2019/04/04 00:20:15.350] (WARN!) : Key: amigacd32amiga
                                ....and so on....
                                Pi 4:
                                Pi Zero 2W:
                                • lhari84
                                  lhari84 @Bkg2k last edited by lhari84
                                  @bkg2k said in Recalbox 6.0 RC2 is released:
                                  Sorry for this one, should have opened my eyes before.
                                  Indeed there was text "ath" in the end of the hash. Must have come form Skraper (Screenscraper) I guess...
                                  Maybe you can have a short look on the other issues I found above.
                                  Thanks for your support!
                                  Pi 4:
                                  Pi Zero 2W:
                                  • Bkg2k
                                    @lhari84 don't worry about such "errors", that's normal, and we'll remove thos logs in the next release.
                                    • lhari84
                                      @bkg2k ok regarding error messages 🙂
                                      But do you have an idea why sega cd isn't working with chd files made from bin/cue roms that work perfectly, though?
                                      Readme says .chd is supported and pcengine cd chd files converted the same way from bin/cue work fine!
                                      I don't know if chd support is new in 6.0 or if it was implemented before. I just can say I don't manage to get it working without a visible reason...
                                      Pi 4:
                                      Pi Zero 2W:
                                        paradadf Staff @lhari84 last edited by
                                        @lhari84 check if changing the core allows you to launch segacd in chd format. It might be that the default core doesn’t support chd, but the other does.
                                        • lhari84
                                          lhari84 @paradadf last edited by lhari84
                                          @paradadf
                                          I've tried already tried switching to genesis plusgx yesterday, no success.
                                          But it's a good hint, appearantly it only works with genesis plusgx core and that's the point. It seems this core needs other bios files (or at least renamed ones), than picodrive core:
                                          https://github.com/RetroPie/RetroPie-Setup/wiki/Sega-CD
                                          I guess I have to approach from this side.
                                          I'll try when I'm at home and report when I get it working.
                                          Pi 4:
                                          Pi Zero 2W:
                                          • abunille
                                            abunille @lhari84 last edited by abunille
                                            @lhari84
                                            Yep, only Genesis Plus GX support .chd extensions.
                                            For both Emulators you need following name convention:
                                            bios_CD_E.bin for Europe Region
                                            bios_CD_U.binfor USA Region
                                            bios_CD_J.binfor Japan Region
                                            Just rename your old Bios filenames to work on both Cores.
                                            (example: eu_mcd2_9306.bin -> bios_CD_E.bin)
                                            paradadf lhari84 2 Replies Last reply Reply Quote 1
