    Recalbox 6.0 RC2 est disponible
    recalbox 6.0 rc2 approche
    47
    195
    100439
      OyyoDams Staff last edited by acris
      Salut les amis! Recalbox 6.0 RC2 est disponible!
      Voici ce qui a été corrigé depuis la RC1:
      • Fix default GBA games metadata
      • Fix old core names in recalbox.conf (automatically renamed)
      • Add Ximo controller to pre-configured pads/joyticks
      • Fix missing desmume_libretro.so
      • Fix reicast on XU4/X86
      • Fix virtual gamepad
      • Fix device handling to quit demo mode
      • Fix Kodi not starting with some gamepad
      • Fix retroarch core options not saved
      • Fix AROS bios with CD32
      • Fix Oricutron conflicts between 2nd player joystick and keyboard
      • Fix Dragonrise on Amiga (partially, you still need to HK+B and reset the emulator)
      • Fix descending sorts in gamelists
      • Improve randomness in demo mode
      Ces bugs ne sont PAS ENCORE corrigés:
      • AdvanceMame configuration not saved (need some code rework and appropriate tests)
      • The internal scraper is not reliable (need some heavy code rework)
      Et juste pour information, l'incroyable "Changelog" de la précédente 6.0 RC1:
      • Major system upgrade. See https://github.com/buildroot/buildroot/blob/2018.02.3/CHANGES#L1-L1427 for the full log
      • KODI b*mped to 17.6
      • Raspberry Pi3b+ and CM3 support
      • Joypads management updated, mostly impacting joypads advertising as a complete keyboard. You have to reconfigure your pad if it is acting strangely
      • Preconfigured gamepads file rewritten
      • arcade GPIO driver upgraded: now support I2C and GPIO recopnfiguring from the command line
      • x86 now requires a CPU that can handle at least SSE and SS2
      • x86: add support for newer AMD GPU
      • fix PS3/PS4 pads not working
      • fix kodi configgen
      • b*mp rpi kernel + firmware
      • gpio arcadedriver works again
      • fix bug on bluetooth discover
      • Add Capcom RB video intro
      • B*mp kodi.plugin.video.youtube to 6.3.1
      • Add support for Mayflash GameCube adapter
      • ES: better cyrillic display
      • Add ipega 9055 udev rule
      • New upgrade procedure to prepare for the future
      • ES: fix scraped folders display
      • ES: improve image loading
      • ES: now automatically reboots once the upgrade is ready
      • Atari 8 Bits: Added Atari 800 and Atari 5200 support - Thanks to dubbows!
      • MSX: Fixed Bluemsx core
      • Add 7z file support for many libretro cores
      • Docker build unified
      • "overlays" folder and roms subfolders automatically created
      • Fix bug on bluetooth discover
      • ES: fix pads buttons detection and configuration
      • Fix bluetooth detection on Odroid XU4
      • Update version of Theodore core (now supports TO8, TO8D, TO9, TO9+ and MO5)
      • Add homebrew game Mission: Liftoff (Theodore)
      • Fix BT recovery on XU4
      • advmame: add overlay possibility
      • MAME: Added mame2003-plus libretro core. A MAME078 version with added games support plus many fixes and improvements.
      • PokeMini: Add Pokémon Mini support
      • FreeIntv: Add Mattel Intellivision support
      • FreeChaF: Add Fairchild Channel F support
      • pc98: Add PC-98xx series support
      • Add Atari Jaguar on x86(_64) platforms
      • SNES9X: Add Satellaview and SuFami Turbo as own systems
      • Neo Geo CD: Added support with fbalpha emulator (TruRip ccd/sub/img recommended)
      • B*mp FBA libretro to latest version => Romset 0.2.97.44
      • B*mp AtariST emulator to december 2018 version
      • Add Oric/Atmos emulator (Oricutron, standalone)
      • Add MGT Sam Coupé emulator (Simcoupe, standalone)
      • c2/xu4: enable generic quirks for usb encoders like Xin-Mo
      • B*mp DosBox to revision 4178 (December 2018)
      • Beetle PC-FX: Add NEC PC-FX support (x86, x86_64 and xu4)
      • MAME bios folders: Update hiscore/cheats for all MAME versions (courtesy of olivierdroid92)
      • B*mp 4DO to support threaded DSP emulation & lightgun
      • Activate 4DO package on Rpi3
      • B*mp Amiberry to 2.24 (SDL2). Compatible Odroid XU4.
      • Add Amiga CD32 system
      • Add AROS bios as default Amiga bios (2019 version)
      • Add configuration for static ip addresses on wifi interfaces
      • B*mp ScummVM/ResidualVM (January 2019)
      • B*mp almost all libretro cores
      • Package names updated (catsfc -> snes9x2005, pocketsnes -> snes9x2002, snes9x_next -> snes9x2010, pce -> mednafen_pce_fast, vb -> mednafen_vb, imame -> mame2000, mame2003 as core name instead of mame078, fbalpha instead of fba)
      • Improved log formatting
      • Add Demo Screensaver
      Bon amusement!
      Bugs confirmed on RC2:
      • Amiga 600 WHDR are not working (fixed for the final release)
      • Mame2003plus - DPAD is not responsive
      Information fichiers dat pour l'arcade
      Les fichiers dat : parent_only, neogeo_only, neogeo_parent_only ne sont plus disponible dans recalbox , vous trouverez les fichiers dat généraux si il existe dans le dossier bios dans share_int ou share.
      bios/fab
      bios/mame2003
      bios/mame2003-plus
      etc...
      Il vous faudra utiliser cette utilitaire pour créer vos fichiers dat personnalisés.
      • utiliser datfile.exe (pour windows) pour créer tes propres fichiers dat en utilisant ce tutoriel https://forum.recalbox.com/topic/4571/tutorial-datutil
      • créer un fichier batch qui permet de générer les fichiers d'un coup.
      Le wiki arcade sera mis à jour en conséquence.
      1 Reply Last reply Reply Quote 7
      • agroum
        agroum last edited by
        super merci beau boulot !!
        ou est ce que post les bugs identifiés
        merci
          OyyoDams Staff @agroum last edited by
          @agroum ici 🙂
          agroum 1 Reply Last reply Reply Quote 0
          • agroum
            agroum @OyyoDams last edited by
            @oyyodams
            merci
            • agroum
              alors pour ma part :
              BIOS a jours
              stockage externe clef USB128
              2 problèmes rencontrer :
              • les images néogeo ont disparu ,
              • le scrap fait planter la Pi a partir de l"édition des données de jeux
              • le dreamcast se lance mais la manette n'est pas reconnue (seul cas rencontrée)
              cordialement
              • Pseudopode
                Pseudopode last edited by
                Tout d'abord un grand, un énorme, un gigantesque merci pour tout ce que vous faites pour votre communauté. 🙂
                La Recalbox ce n'est pas que du souvenir en boîte mais du bonheur en boîte. 😄
                Je me permets de signaler un souci rencontré avec la version 6.0RC1 mais aussi avec la RC2.
                L'image des jeux MAME ou FBA Libretro semble avoir son ratio de changé comme d'autres utilisateurs l'ont constaté.
                Avec les overlays de ScreenScrapper, même à jour, l'image est tronquée dans le sens de la largeur.
                Par exemple avec un jeu comme Alien vs Predator dans l'écran de sélection des personnages leurs fiches sont tronquées.
                18.07.13
                6.0RC1/RC2
                J'ai vérifié le fichier common.cfg et son contenu est identique dans la nouvelle version des overlays à celui de l'ancienne version.
                Merci encore à vous. 🙂
                • ViRuS-MaN
                  ViRuS-MaN last edited by
                  bon sur pi3 dans un bartop je ne parviens a faire fonctionner mes manette en gpio alors que sur la derniere stable cela fonctionner nickel
                  • Judge
                    Judge last edited by
                    Soucis avec RC2, impossible de sauvegarder les changements de shader dans retroarch, ça me marque Error.
                    (Pi3b, RC2 (maj de RC1 propre), Alim5V3A dans nespicase)
                    Pi3b dans nespicase, SD 64Go et HDD2T ext, stick arcade Mayflash F300 & manette ps3
                      @agroum
                      • ta gamelist neogeo est sans doute corrompu, sauvegarde là puis supprime là et rescrappe avec un scrappeur externe.
                      • on a dit que le scrap interne ne fonctionnait pas et qu'il faut utiliser des logiciels externes de scrap
                      • as tu reconfiguré ta manette et retester avec la dreamcast, si oui, il faut relancer un jeu et poster une archive de support.
                      @Pseudopode
                      peut on avoir un extrait des fichiers overlay de mame et du jeu en question.
                      • Otnarac
                        Otnarac last edited by
                        Hello,
                        J'ai pas trouvé l'information ailleurs (liens plus à jours), ni de sujet qui traite de l'informations mais est ce que dans la RC2 les fichiers .dat pour fba_Libretro 0.2.97.44 seront mis à jour dans le dossier clrmanepro ?
                        Je galère à trouver le fichier parent_only
                        • johnodon
                          johnodon last edited by
                          RC2 x64
                          Lenovo T430
                          RB installed on USB flash drive
                          ROMs store on internal HDD
                          The issue with SNES .zip files being extracted into the rom folder and remaining there (as .sfc) still exists. This causes an issue as the next time the scraper is run, you get duplicate entries in your gamelist.
                          Workaround is to use uncompressed (.sfc) files.
                          John
                          • jejehtc
                            jejehtc last edited by
                            On peut installer la RC2 directement sur la stable 4.1sans perdre nos donées?
                            Bkg2k Otnarac 2 Replies Last reply Reply Quote 0
                            • Bkg2k
                              Bkg2k Staff @jejehtc last edited by
                              @jejehtc Non, il faut faire une sauvegarde de tes données avant: roms, bios et saves à minima.
                              • Otnarac
                                Otnarac @jejehtc last edited by
                                @jejehtc Toi .... tu va prendre une fessée avec ce genre de question .... 🙂
                                Si tes données sont sur clé USB/DD oui. Il faut renommer le fichier recalbox de la clé en recalbox.old puis une fois l'installation réalisé avec la RC2 sur la clé, copier les dossier Bios, roms et save de recalbox.old vers le dossier recalbox.
                                Si tes données sont sur la SD alors non, car de la 4.1 a RC2 c'est installarion propre et donc formatage (=perte des données) donc faire une sauvegarde des dossiers cités plus haut avant
                                marwin91 1 Reply Last reply Reply Quote 0
                                • loli72
                                  loli72 last edited by
                                  J'ai refais quelques tests sur Odroid XU4 et voici mes premiers retours :
                                  • la Dreamcast est parfaitement opérationnelle : son et framerate,
                                    mais sur la RC1 le jeux Nomade soul s'était enfin décidé à fonctionner correctement, sur la RC2 on retrouve de nouveau l’affichage sur la moitié gauche de l'écran seulement. Du coup je me demandais s'il n'y avait pas à creuser du cotè du bug Dreamcast de la RC1 ou Nomade soul fonctionnait pour enfin le voir tourner sur Odroid au moins.
                                  • il reste encore un petit moment de pixellisation au démarrage de recalbox pendant le chargement d'ES et la musique du thème d'origine ne démarre pas, sur la RC1 non plus. La musique revient lorsque l'on quitte le premier jeux et qu'on retourne sur ES.
                                  • Les fréquences proposées en overclocking me paraissent toujours étranges par rapport aux fréquences des ARM de l'Odroid (de 900 à 1100MHz alors que le XU4 tourne autour de 2Ghz)
                                  Sinon on s'approche du Graal là , c'est bon vous êtes sur la bonne voix.
                                  Et merci pour tout le boulot que vous abattez et pour votre patience au bureau des plaintes.
                                    • RPI3b+
                                    • Scandisk 16 Go class 10
                                    • Alim 5v 2.5A officiel
                                    • Thème par défaut
                                    • Update RC1 -> RC2
                                    Test de l'emulateur avec prboom :
                                    • prboom.cfg par défaut absent du dossier /share_int/roms/prboom
                                    • musique absente lorsque l'on joue à différents doom-like, les bruitages fonctionnent
                                    • Les jeux/musiques provient de la version stable qui fonctionnent.
                                    Ouverture d'une issue : https://gitlab.com/recalbox/recalbox/issues/684
                                    Voir aussi : https://forum.recalbox.com/topic/16960/prboom-doom-fichier-config
                                    • Pseudopode
                                      @acris je transmets tout ça demain. Bonne soirée à tout le monde. 🙂
                                        acris @Otnarac last edited by acris
                                        Bonjour @Otnarac
                                        Il semblerait que
                                        @otnarac said in Recalbox 6.0 RC2 est disponible:
                                        Hello,
                                        la team est décidé de ne plus donner l'accès à ces fichiers. Le fichier dat pour chaque emulateur arcade se situe dans le dossier bios
                                        bios/fab
                                        bios/mame2003
                                        bios/mame2003-plus
                                        etc...
                                        du coup tu dois apprendre à :
                                        Otnarac 1 Reply Last reply Reply Quote 0
                                        • Bkg2k
                                          Bkg2k Staff @loli72 last edited by
                                          @loli72 alors c'est ce que j'essayais d'expliquer à quelqu'un qui nous a dit "à quoi ça sert de mettre à jour les émulateur?".
                                          Dans la RC1, la XU4 a bénéficié du dernier Reicast. Hors, si ce dernier fonctionnait bien sur Pi3, sur XU4, il avait un certain nombre de problème...
                                          Nous avons du donc revenir en arrière pour Reicast, sur le XU.
                                          Donc ce n'est une question de "réglage". Nous n'intervenons que le minimum possible sur les émulateurs, afin de pouvoir les mettre à jour le plus facilement possible.
                                          Au mieux, nous pouvons agir sur quelques options de compil, ce que nous feront certainement plus tard pour essayer d'avoir du mieux sur le XU4.
                                          Mais il ne faut pas s'attendre à des miracles, et il faudra certainement attendre que l'émulateur évolue avant de tenter un nouveau b*mp.
                                          loli72 1 Reply Last reply Reply Quote 0
                                          • goeland
                                            goeland last edited by
                                            Juste un grand merci pour votre travail.
                                            Raspberry Pi3 B+
                                            Lenovo Tiny P330
                                            Manettes
                                            • 8BitDO SN30 Pro
                                            • Hori Battle Pad Manette Filaire Type GameCube
                                              Version RecalBOX Recalbox 9.1 Pulstar
                                            bundy 1 Reply Last reply Reply Quote 1
