    Anyone using an Intel NUC with Recalbox?
    Your discoveries
    anyone intel nuc recalbox
    8
    20
    9681
    • MilesCW
      MilesCW last edited by
      Hello there,
      I'm new to the Intel NUC series and simply want to ask you guys if anyone has a working NUC with Recalbox on it. As far as I've read online there're some models which are noisy and other don't work at all.
      Thanks!
      joinski 1 Reply Last reply Reply Quote 0
      • joinski
        joinski @MilesCW last edited by joinski
        @milescw
        I'm using 2 models of Intel NUC with Recalbox and both working fine.
        The first one is a NUC-Kit DC53427HYE and the other one is a NUC-Kit D54250WYK.
        For the DC53427HYE, you can adjust the fan in BIOS settings, so that it will run relatively quiet.
        For the D54250WYK, you could also adjust the fan in BIOS settings, but i bought a passive cooled case (Akasa Tesla H http://www.akasa.com.tw/update.php?tpl=product/product.detail.tpl&no=181&type=Fanless Chassis&type_sub=Fanless NUC&model=A-NUC05-A1B), so that i have absolutely silence.
        • olivierdroid92
          @joinski
          Hi
          Can you please tell us if you are running games with Dreamcast or GameCube?
          • MilesCW
            @joinski
            I see. I'm considering getting an Intel NUC7I3BNH for Wii/GameCube/Dreamcast Emulation. Do you think this would be enough if you compare it with your system? How well does the emulation works on it?
              voljega Banned @MilesCW last edited by
              @milescw not enough for gamecube
              • joinski
                joinski @olivierdroid92 last edited by OyyoDams
                @olivierdroid92
                Gamecube and Dreamcast runs very well (but on the DC53427HYE i have a few slow downs in some Gamecube games). But i did test only a few games like Crazy Taxi and Mario Kart DoubleDash yet.
                I do not know, how many Dreamcast and Gamecube games will run good on the NUC. You should just test for yourself.
                @MilesCW
                Should run even better because of Intel HD Graphics 620
                @voljega
                Why should it be not enough for Gamecube?
                @olivierdroid92 and @MilesCW
                For Gamecube i would suggest to use *moderated*, because it runs a bit better then Recalbox.
                I do not know why, but maybe it is because of a different Dolphin Version?
                Recalbox uses Dolphin Version 18.07.13-dirty and *moderated* uses Dolphin 2018.05-rc2-3120.
                voljega 1 Reply Last reply Reply Quote -1
                  voljega Banned @joinski last edited by
                  @joinski because several users reported there that gamecube on recalbox needed at least 3Ghz of processing power to be perfectly smooth.
                  • joinski
                    joinski @voljega last edited by OyyoDams
                    @voljega
                    my experience is different. In Gamecube emulation CPU- and GPU-Power are almost same important. Newer Generation CPUs (at least Core i3) do not need >3GHz to have good performance. Even some Pentium G (G3220 for example) with Intel HD Graphics are fast enough to run Gamecube Games in native resolution at full speed.
                    look here:
                    MODERATION TEAM - Link removed
                      voljega Banned @joinski last edited by OyyoDams
                      @joinski this is not recalbox, the implementation is not the same or not in the same version, so it's a pretty pointless comparison
                      in your previous message you say yourself you experienced slowdown and didn't tested much games so ...
                      joinski 1 Reply Last reply Reply Quote 1
                      • joinski
                        @voljega
                        i will do a comparision with Recalbox if wanted.
                        do you have any specific Gamecube games you want me to test with Recalbox?
                        • MilesCW
                          @joinski
                          Nothing comes to my mind - but thanks for the offer!
                            @joinski Try any Rogue Squadron or Viewtiful Joe
                            • joinski
                              @voljega
                              Viewtiful Joe runs perfect at 60fps.
                              But Rogue Squadron II unfortunately is unplayable. It runs only with 30-50fps and has graphical glitches.
                              • overunity
                                overunity last edited by
                                FYI: I just tried BOXNUC7CJYH1. Recalbox menu is unusable, registering 'key press' about 1 every 30 secs.
                                Thats on Intel UHD 600 graphics.
                                • olivierdroid92
                                  @overunity
                                  Thanks for the feedback.
                                  I am very disapointed as I planed to buy the same.
                                  Any chanche to record and share a video to show us the issue with the menu ?
                                  Also if you 're in position to record a short video with a least 1 game will help us.
                                  • joinski
                                    joinski @overunity last edited by
                                    @overunity
                                    maybe you can try the fork of recalbox?
                                    unfortunately it is not allowed here, to mention the name of it 😞
                                      paradadf Staff @olivierdroid92 last edited by
                                      @olivierdroid92 ich würde dir einfach nur empfehlen, ein bisschen mehr Geduld zu haben. Bald wird Buildroot aktualisiert und damit Kernel, Treiber und Co. auch. Dann sollte vieles funktionieren 😉
                                      • luciferwhite
                                        luciferwhite Banned last edited by
                                        This post is deleted!
                                        • em.83
                                          em.83 last edited by
                                          Hi,
                                          Please, does anyone know a NUC that runs well DS emulation on Recalbox ?
                                          • olivierdroid92
                                            @paradadf
                                            Thanks a lot
