    Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...)
    Testers's corner
    testers wanted major upgrade pi3b
    198
    805
    920140
    • Marco Polo
      Marco Polo last edited by Marco Polo
      Ça y est j'ai sauter le pas 😛 par contre il m'est impossible d’associer ma 8bitdo NES30 Pro, il la trouve bien mais "impossible d'associer la manette" 😕 et les touche A et B sont inverser sur ma manette filaire Xbox !
      • olivierdroid92
        @OyyoDams
        I think there is a SSH issue
        Image : 2018.12.24.Christmas.Beta on XU4 = SSH access failed
        Image : 2018.12.24.Christmas.Beta on RPI3B = SSH access failed
        Image : 2018.07.13 on both RPI3 and XU4 = SSH access granted
        x08fd 1 Reply Last reply Reply Quote 0
        • x08fd
          x08fd @olivierdroid92 last edited by
          @olivierdroid92 said in Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...):
          @OyyoDams
          I somehow experienced the same. I actually was able to SSH in, but since I have chosen external storage devices, SSH will tell me the connection was closed by xxxx. Not sure if those are related.
          • x08fd
            x08fd last edited by
            I'm fairly new here, Christmas beta was actually the first recalbox I have installed on RPI3B+.
            This is driving me nuts. I tried to modify the save/load state keys mapping and change to left/right shoulder button. However, every time I modify the file retroarchcustom.cfg, it gets reverted once I enter the game. With a yellow text below saying "Configuration Override loaded", which I assume was doing the change.
            I also modified the input/DEFAULT.cfg file but it doesn't seem helpful either.
            And the config file in share_init folder, I modified what I could find, not helpful.
            So who's reverting those files? I'm rather confused. What should I do to change those settings?
            • olivierdroid92
              @x08fd , @OyyoDams
              You are right !
              On RPI3B, image 2018.12.24.Christmas.Beta
              • with storage set as INTERNAL, SSH access WORKS,
              • with storage set as USB Stick, SSH access FAILED.
              • lhari84
                lhari84 @lhari84 last edited by lhari84
                @lhari84 said in Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...):
                @lhari84
                Sorry, have to reply instead of further updating last post, because of some spam protection...:
                Really have troubles with Wifi, connection just crashes when copying just 16 Megabytes of savegames by using SMB share.
                Can exclude a problem with my Wifi, all clients, including latest Recalbox stable work like a charm with my wireless network, so problem occurs with latest beta only.
                See screenshot (ping) too, in the end copy process crashes because auf connection loss:
                Also interferrence with bluetooth controller is still present.
                And I'm using Pi 3 B+ for testing.
                Hi,
                In the meanwhile I have changed my Repeater, since I had another one for backup.
                Here I used the 5 GHz network and everything seems to work fine. No bluetooth issues, no fail of connection when copying files....
                Old repeater: TP-Link RE450 v1
                New repeater: Fritz! Repeater 1750E
                ... both with latest firmware installed.
                So in conclusion I cannot say if it's a 2,4 GHz problem (with many or all routers/repeaters affected), or it's just a problem with that christmas beta has with TP-Link RE450 v1... But there is a problem for sure, because as mentioned, I never had any problem with the old repeater in cooperation with other devices/systems.
                Hope this information helps to improve.
                Pi 4:
                Sony DualShock 4 (2nd gen), 8BitDo Pro 2, 8BitDo SF30 PRO, Retroflag SUPERPi 4 Case, Recalbox 9.0
                Pi Zero 2W:
                GPi Case 2W, Recalbox 9.0
                  OyyoDams Staff @olivierdroid92 last edited by
                  @olivierdroid92 in this case this cannot be Recalbox related, but on the client side.
                  • Marco Polo
                    Amiga 600, 1200, Atari ST et Commodore 64 ne fonctionne pas, quand je lance un jeu cela revient a la liste des jeux ! 8bitdo NES30 Pro, il la trouve bien mais "impossible d'associer la manette"
                      acris @Marco Polo last edited by acris
                      @marco-polo said in Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...):
                      Bonjour @Marco-Polo
                      Un peu plus de detail serait apprécié surtout que la version christmas est multi plateforme.
                      Rpi ? Odroid ? Pc ?
                      Les bios sont en place ? Les extensions so
                      Des roms sont corretes ?
                      Marco Polo 1 Reply Last reply Reply Quote 0
                      • Skrelox
                        Skrelox @fosi last edited by
                        @fosi said in Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...):
                        Hello I made a fresch flash with the Christmas beta and now the Dreamcast games don't start anymore.
                        Anybody else have this problem?
                        Hello everyone,
                        First, thanks to the developers for their work 🙂
                        I have the same problem as fosi, the Dreamcast emulator doesn’t work on RPI 3b + with the latest update 2018.12.24.Christmas.Beta
                        It's as if the bios are not present, whereas they are in the good folder.
                        The emulator worked with the beta 11/29/18 with the same bios.
                        Someone have an idea ?
                        Mon anglais n'est pas très bon alors je poste aussi en français.
                        Tout d’abord merci au développeurs pour leurs travailles 🙂
                        J’ai le même problème que  fosi  , l’émulateur Dreamcast ne fonctionne plus sur RPI 3b+  avec la dernière mise a jour 2018.12.24.Christmas.Beta
                        C’est comme si les bios n’étaient pas dans le dossier, alors qu’ils y sont...
                        L’émulateur fonctionnait avec la beta 11/29/18 avec les même bios.
                        Quelqu un à une idée ?
                        BriKKou 1 Reply Last reply Reply Quote 1
                        • Bkg2k
                          Bkg2k Staff last edited by
                          When posting a bug report, please be as much accurate as you can.
                          If possible, tell us:
                          • The hardware your recalbox is running on
                          • Anything specific in your configuration (exotic pad? HDD? USB? Network, ...)
                          • Default or user/custom theme?
                          • Optionnaly, if you have a big game collection, how many systems/games.
                          When a particular emulator is not working:
                          • Rom/game extentions
                          • BIOS
                          • Pad(s)
                          The last beta has been released on many systems, and every single system has its own particularities!
                          Without details, we won't be able to help you!
                          Lorsque vous rapportez un ou des bug(s), soyez le plus précis possible!
                          Essayez d'indiquer:
                          • Le hardware sur lequel tourne votre recalbox
                          • Tout ce qui est spécifique à votre configuration (HDD, Reseau, USB, pad exotiques, ...)
                          • Thème par défaut ou thème custom/utilisateur?
                          • Optionnellement, si vous avez une grosse collection, le nombre de systèmes et de jeux.
                          Si un émulateur en particulier ne fonctionne pas:
                          • L'extension du jeu ou de la rom
                          • Le(s) BIOS utilisé(s)
                          • Le(s) Pad(s) utilisé(s)
                          La dernière bêta est sortie sur tous les systèmes, et chaque système a ses propres particularités!
                          Sans indications, il nous est peu ou pas possible de vous aider.
                          1 Reply Last reply Reply Quote 4
                          • Sp0oNy
                            Sp0oNy last edited by
                            Hello,
                            Merci pour le taf, cette nouvelle Beta semble vraiment s'approcher de la version finale 🙂
                            Install : nouvelle install sur SDCard
                            Système : Pi3B+
                            Deux problèmes identifiés (que je n'avais pas sur la précédente Beta) :
                            1. La liste des favoris se réinitialise au reboot (retour aux favoris par défaut)
                            2. Le scrapping ne semble pas enregistrer, et il n'est pas possible de l'arrêter...
                              @Sp0oNy
                              les roms sont sur microsd ou support externe ? support externe fat32 exfat ?
                              Sp0oNy 1 Reply Last reply Reply Quote 0
                              • olivierdroid92
                                olivierdroid92 Global moderator @OyyoDams last edited by olivierdroid92
                                @oyyodams , @Bkg2k
                                SSH acces
                                Board : RPI3B
                                CASE A
                                from fresh install on SD card. No ROM, No bios, No USB Key, USB Wired Pad with RJ-45 cable, no wifi.
                                Pad remapped after 1st boot
                                SSH access works.
                                From /var/log/messages I can read
                                Dec 26 14:49:18 RECALBOX authpriv.info dropbear[1398]: Child connection from 192.168.4.107:55300
                                Dec 26 14:49:45 RECALBOX authpriv.notice dropbear[1398]: Password auth succeeded for 'root' from 192.168.4.107:55300
                                CASE B
                                from fresh install on SD card AND New 7Go USB key FAT32 Formatted, empty. No ROM, No bios, USB Wired Pad with RJ-45 cable, no wifi.
                                SSH access do not works.
                                Dec 26 14:46:43 RECALBOX authpriv.info dropbear[1413]: Child connection from 192.168.4.107:55274
                                Dec 26 14:46:43 RECALBOX authpriv.err dropbear[1413]: Failed moving key file to /etc/dropbear/dropbear_ecdsa_host_key: Operation not permitted
                                Dec 26 14:46:43 RECALBOX authpriv.info dropbear[1413]: Exit before auth: Couldn't read or generate hostkey /etc/dropbear/dropbear_ecdsa_host_key
                                • Marco Polo
                                  Marco Polo @acris last edited by Marco Polo
                                  @acris Bonjours,
                                  Oups désolé, sur Odroid(nespicase) Samdisk Ultra 200go, câble réseau(wifi na jamais fonctionner pour moi) les bios sont en place, les extensions, tout est ok, les roms aussi(en tout les cas elle fonctionnais avec la dernière mise a jours bêta non christmas)
                                  Et pour le 8bitdo NES30 Pro et bien A et B sont inverser, lorsque je veut confirmer la configuration de celui ci je suit obliger de faire B et non A pour confirmer, alors que j'ai bien configurer les touches A pour A et B pour B !
                                  • olivierdroid92
                                    @Sp0oNy @acris
                                    Same for me
                                    Board : RPI3 and XU4
                                    Image : Image : 2018.12.24.Christmas.Beta
                                    from fresh install on SD card for OS,
                                    with USB card (FAT32 Formatted, for BIOS and ROMs small collection) & USB Wired Pad & RJ-45 cable, no wifi
                                    No image appear after scrapping
                                    No favories saved after restar
                                    • Bkg2k
                                      Bkg2k Staff @olivierdroid92 last edited by
                                      @olivierdroid92 Merci pour les infos et les tests sur la connexion SSH, on va investiguer de ce coté.
                                      Pour les scrape "sans image", il s'agit du scraper interne ou d'un externe?
                                      Jass76 1 Reply Last reply Reply Quote 0
                                      • Sp0oNy
                                        Sp0oNy @acris last edited by
                                        @acris said in Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...):
                                        Tout sur la SD : 128Go formatée en Fat32.
                                        A noter : je ne l'ai pas reformatée entre la beta précédente et celle-ci, juste passé par Etcher.
                                        • olivierdroid92
                                          @Bkg2k
                                          Pour le scrap, c'est en interne avec "Screenscrapper" intégré à RCB
                                          • Bkg2k
                                            @olivierdroid92 Ok, tu peux m'envoyer en MP, le block XML du jeu scrapé, dans ton gamelist.xml?
                                            simba51 1 Reply Last reply Reply Quote 1
