    Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...)
    Testers's corner
    testers wanted major upgrade pi3b
    198
    805
    920087
    • Pattick76
      Pattick76 @OyyoDams last edited by
      @oyyodams Merry Christmas to everybody!🎄How can I update my existing beta on my Raspi3B+ -Multibootsystem? Is there any link online for inserting into the Recalbox config-file for just updating only the recalbox-system like before via menu, because writing a complete recalbox-image will erase my other 2 systems (Raspbian & Libreelec) on my raspberry 3B+ preferred SD-Card? (My games are stored on external USB). I don't want to switch the SD-Cards for playing.😉!🎮
      Thanks for help.🤓
      • lhari84
        lhari84 last edited by lhari84
        Hi,
        Thanks for new release! First, in my point of view it‘s a good decision making a hard cut when changes in new version are too complex for an update. Doing a fresh installation is no big deal at all an I‘m sure it avoids mans update related issues.
        Unfortunately I also have to report an issue, Wifi still seems to make some troubles:
        It seems it connects faster and more stable than latest beta, but on my side there are heavy interferrences with internal bluetooth. I‘m connected to a 2,4 GHz network and as soon as I activate Wifi, Bluetooth lags or even loses connection until i go closer (reduce distance to <2 meters).
        Further I want do report that Recalbox (or Emulationstation) hang about at least 1 minute after first Wifi activation. No reaction at all. Already wanted to remove power supply when it suddenly has shown message „Wifi activated“ though.
        Thanks for spending so many of your time for this project, it‘s really great and I‘m looking forward to final new version. Especially because I have big issues with all newer 8bitdo controllers (random loss of whole pairing), which seems to be gone with new version!
        and: Happy x-mas! 🙂
        Edit:
        Please ignore interferrence issue for now. Rebooted my Wifi Repeater and it‘s gone for now. Haven‘t ever had such an issue befor, I‘ll keep you informed.
        Pi 4:
        Sony DualShock 4 (2nd gen), 8BitDo Pro 2, 8BitDo SF30 PRO, Retroflag SUPERPi 4 Case, Recalbox 9.0
        Pi Zero 2W:
        GPi Case 2W, Recalbox 9.0
        lhari84 1 Reply Last reply Reply Quote 0
        • Marco Polo
          Marco Polo last edited by
          Bonjours et bonne fêtes@tous
          J'ai pas tout compris, Il faut effacer si on veut la nouvelle version? Pas d'upgrade possible?
          • lhari84
            lhari84 @lhari84 last edited by lhari84
            @lhari84
            Sorry, have to reply instead of further updating last post, because of some spam protection...:
            Really have troubles with Wifi, connection just crashes when copying just 16 Megabytes of savegames by using SMB share.
            Can exclude a problem with my Wifi, all clients, including latest Recalbox stable work like a charm with my wireless network, so problem occurs with latest beta only.
            See screenshot (ping) too, in the end copy process crashes because auf connection loss:
            Also interferrence with bluetooth controller is still present.
            And I'm using Pi 3 B+ for testing.
            Pi 4:
            Pi Zero 2W:
              paradadf Staff @Pattick76 last edited by
              @pattick76 please read the first post. No update possible.
              Pattick76 1 Reply Last reply Reply Quote 0
              • audrik
                audrik last edited by
                Atari 800 -> RPi 3B = OK
                Atari 7800 -> RPi 3B = OK
                Atari 800 -> PC 64bits = ne se lance pas
                Atari 7800 -> PC 64bits = ne se lance pas
                • fosi
                  fosi last edited by
                  Hello I made a fresch flash with the Christmas beta and now the Dreamcast games don't start anymore.
                  Anybody else have this problem?
                  Skrelox 1 Reply Last reply Reply Quote 0
                  • olivierdroid92
                    @OyyoDams, @paradadf
                    Dear All dev team
                    Thanks a lot for all works performed
                    Board : XU4
                    Image : 2018.12.24.Christmas.Beta
                    Issue : I can not connect with SSH,
                    also, I failed to get support archive link 😞
                    Regards
                      OyyoDams Staff @olivierdroid92 last edited by
                      @olivierdroid92 maybe because old ssh keys are still registered in putty, try to reset them
                      • smashboy2000
                        smashboy2000 @olivierdroid92 last edited by
                        @olivierdroid92 J'ai eu le même problème : il faut appuyer très légèrement sur L2 et R2 sinon ça s'emballe.
                        I had the same issue : you have to press L2 and R2 gently or you'll get into trouble.
                          OyyoDams Staff @smashboy2000 last edited by
                          @smashboy2000 quel rapport entre putty et L2/R2 ?
                          smashboy2000 1 Reply Last reply Reply Quote 0
                          • smashboy2000
                            smashboy2000 @OyyoDams last edited by
                            @oyyodams Aucun : regarde le message auquel je répond.
                            ... Oh flûte, j'ai répondu à un message vieux de 4 mois en croyant qu'il venait d'être posté.
                            Cette page regroupe toutes les updates en fait, c'est ça ? (j'suis encore novice dans ce forum)
                            • smashboy2000
                              Après une petite demi-heure de test sur mon Rapsberry Pi 3, quelques conclusions :
                              • Tous les jeux qui fonctionnaient avant, fonctionnent toujours
                              • Mes jeux PSP ne fonctionnaient pas : c'est dorénavant le cas ^^
                              • Seul problème rencontré : au moment de configurer la manette PS4, il m'est impossible d'assigner le touchpad à un bouton
                              Je n'utilise pas le Wi-Fi ni de clavier, je n'ai donc pas pu essayer.
                              • olivierdroid92
                                olivierdroid92 Global moderator @OyyoDams last edited by olivierdroid92
                                @oyyodams
                                Board : XU4 (192.168.4.105)
                                I've tried again with another system and can not acces to XU4 using SSH0_1545760613728_Capture du 2018-12-25 18-51-30.png
                                I did not get the box to update key
                                Board : RPI3B (192.168.4.106)
                                Image : 2018-07-13
                                It's work
                                I confirm key was updated
                                • Marco Polo
                                  Pas d'update c'est bien pour ceux qui non encore rien installer sur leurs PI3B+ mais pour les autres il faut attendre une mise a jour ou c'est mort??
                                    OyyoDams Staff @Marco Polo last edited by
                                    @marco-polo vu la complexité de cette mise à jour, il est difficilement concevable d'envisager une mise à jour standard justement. Prévois un backup de tes roms 😉
                                    Marco Polo 1 Reply Last reply Reply Quote 1
                                    • Pattick76
                                      Pattick76 @paradadf last edited by
                                      @paradadf B*mp 507 RPI3 (2018/11/12) beta was the best release for me! Running like a stable release with everything working. All my games from 20 Systems, PS4-Bluetooth-Controller, 5GHz-Wifi,1500Mhz-overclocking, overall stability on my RPi3B+...everything just running perfectly. Nice to have it. Thanks for good work!
                                      Where can I find my UI-settings, overall gameplay- and emulatorsettings, audio etc. stored to copy&paste them later into the future final release (foldername?/filename?)? Not all my menu-settings are stored in the recalbox.conf(?). (My games are stored on external USB-drive.)
                                      Thanks for reply. 🤓
                                      • Marco Polo
                                        Marco Polo @OyyoDams last edited by
                                        @oyyodams Je vais prévoir cela, en tout cas super taf de la team Recalbox et beau cadeau de noël pour les Retro Gamers que nous sommes ^^
                                        Juste les roms pour le backup pas autre choses avant de me lancer?
                                        • Mathis Demonceaux
                                          Mathis Demonceaux last edited by
                                          Bonjour je joue avec une manette PS4 dans les menus celle ci ne fonctionne dans aucun jeu
                                          • Mathis Demonceaux
                                            J'utilise un raspberry pi 3 b+
