    Recalbox 18.07.13 is out!
    Announcements
    recalbox 18.07.13 out
    24
    59
    51118
      @anderdog
      Bug in Kodi... pressing the button without stopping, turbo type... even if you do not press anything in the menus.
      Usually starts in the menu options, System🤬 Fix??? I use ps4 controller🤔
      Go to Main Menu, "Controller Settings", "Configure a Controller", do the Button Mapping for your Controller.
      • Rivalus
        Rivalus last edited by
        Thank you very much for the hard work. Just one question, What Kodi version Recalbox using now? I want to migrate my Kodi to Recalbox, but Addon for TheTVDB.com doesn't work anymore in version 16, it require version 17.
        • Abilaunken
          Abilaunken last edited by Abilaunken
          I have a problem with this 18.07.13 release, almost all cores get blackscreen but the games run and have sound.
          I found a simple fix but its a bug: Go to main menu, inside "game settings" and select some shader.
          This seems to fix glupen64/mupen/neogeo,etc but not fba like cp1/cps2/cp3 steal blackscreen with sound.
          If i set shaders none almost no game work... my god thats why i always fear to update.
          Well i found a way, set shader with scanlines or retro, but up some neogeo game and change the game in the retroarch menu with the load content.
          With this work around i can get any cps game to work, i simple cant start cps by its on with this build.
          Lets just wait for another update to see if fix the need of shader and this blackscreens.
            Substring @Abilaunken last edited by Substring
            @abilaunken which board ? Pi3 ? Default theme ? What screen ? Overclocked ?
            Abilaunken 1 Reply Last reply Reply Quote 0
            • Abilaunken
              Abilaunken @Substring last edited by Abilaunken
              @substring
              Pi3, i try change themes for default "recalbox" and nothing changes.
              After update the overclock goes 1300 to 1200 so i can say a tested with and without, same results.
              My last update was 1 plus the one with christmas intro and everything works until now.
              Now i got almost all core blackscreen until a set a global shader in the ES main menu.
              Try put shader = none and see if u can play neogeo or other games.
                @abilaunken altough i have a small idea of what could be wrong, this hasn't changed for months ...
                What.s your screen ?
                • Abilaunken
                  @substring said in Recalbox 18.07.13 is out!:
                  What u mean when u ask me about "screen" ?
                  What make me mad is the fact that anyone here doenst report this bad behavier, i always look about the update before in fact update.
                  What i read was about the select button and the coin in arcades, but was fix in this release. Something about the n64 blackscreen, but the problem about blackscreen its something more.
                  Do u know if its possible to downgrade?
                  This 18.07.13 should not be in the stable updates, at max on the instable, but for me it should have been more work on it.
                  Im not a linux expert, but i suspect the problem is on some ".sh" scripts, in the launch of the retroarch core and contets line from the EmuStation.
                  The proof is that i can open and play content of fba that is not loading properly directly from Emustation resulting blackscreen, when i open inside the retroarch.
                    @abilaunken if no one reported the problem (well, a few did), it's because it's not happening to most people.
                    If i ask you details about your screen, is that I suspect that the delay added after resolution change could be too short. That's somethibg we had to deal with about a year ago with a pi firmware change
                    Abilaunken 2 Replies Last reply Reply Quote 0
                    • Abilaunken
                      Humm the change in resolutions humm... i use a samsung model 6 not the best for games, i set my hdmi for pc to get the best of input lag i can get, its somewhere between 40 and 50 ms lag.
                      But i think input lag has nothing to do in the change of resolutions.
                      So you suspect that when i set some shader in the ES when i launch a game i get more milliseconds to open a game or get a extra pass thats why i got some games to launch properly. Hum make sence...
                      Do you know a way that i can put a thered sleep of 100ms or something to test?
                      • Abilaunken
                        @substring
                        Sub i now managed to fix all the blackscreen in all cores and was a simple fix.
                        In the recalbox.conf just comment this line with a "#" :
                        Set gpslp shader for all emulators (prefer shadersets above). Absolute path (string)
                        #global.shaders= one
                        I mess with resolution like u tell but nothing fix the problem, so a left global.shaderset=none , thats cause blackscreen in almost all cores, but when i set global.shaders= with absolute path all cores work perfect.
                        But i cant do that becouse the compatibility issues with some cores like psx that get slows down, so u just need to comment this line and without no shaders no more bug.
                        Forget it, its works until i reboot... something reallly messed up and change behavier when mess with shaders.
                        Its a lost of time trying to discover a work around, just wait another release.
                        Put retro or scanline load some core and content and be happy to play cps1 this way for now.
                          @abilaunken yoi can exchange global with a system name like nes.shaderset
                          • Abilaunken
                            nes.shaderset
                            I tryed the tag "nes.shaderset" but does nothing, when i put global.shaders=/recalbox/share_init/shaders/crt-caligari.glslp all core works ok, but psx geting really low speed.
                            If i discover a way to make him exclusive whitout a shader, maybe override the core whith no shader is possible but i dont know it can override a empty shader.
                            • Abilaunken
                              @substring
                              Tried override core but doesnt override shaders, but if i dont put any shader i get blackscreen on psx anyway damed!
                              I found another bug, final burn alpha now has only (fba2x) core ? Thats why i can only play some games loading content after playing a neogeo game.
                              The fix is to move to fba_libretro folder, but i dont know it will get fix on the next releases or its right and fba should only have fba2x and libetro has fba core.
                              Anyway, cant play almost nothing if a dont put the scaline or retro shader.
                              If no shader blackscreen with the game runing with sound in background.
                              Lost bluetooth battery indicator too, before update it worked and i liked.
                                @abilaunken fba and fba2x have always been 2 different systems as their romset are totally différent
                                • Abilaunken
                                  @substring yeap, im saying the folder fba once work with other core before and now only with fba2x.
                                    @abilaunken this was a mistake
                                    • Dragu
                                      Dragu Banned last edited by
                                      @Substring
                                      J'ai vu que la version 18.07.13 a un driver hi_dr.ko dragonrise différent, mais avec les erreurs connus de définitions de l'axe verticale du joystick. Si quelqu'un a un problème faudra le remplacer par cette version
                                      https://forum.recalbox.com/topic/13213/direction-joy-amiga-pas-de-haut-ni-de-bas-ni-bouton-2/9
                                        Substring @Dragu last edited by
                                        @dragu le problème c'est que je n'ai aucun code source valable pour ce correctif
                                        • joe654
                                          joe654 last edited by
                                          Thank you for sharing this information with us.
                                          https://hpsupports.co/hp-support-assistant/
                                          100.3k
