    [SOFT] Skraper
    Community projects
    [soft] skraper
    76
    305
    270922
    • NukeThePeace
      NukeThePeace @NukeThePeace last edited by
      Happens with all systems installed, use Emulationstation on windows. PS. Also it ignores text case (always uses "as is" insted of lower case or uppercase.
      • Bkg2k
        Bkg2k Staff last edited by
        Try the latest beta:
        https://www.skraper.net/download/beta/SkraperUI_Beta7.4.2.x86.7z
        https://www.skraper.net/download/beta/SkraperUI_Beta7.4.2.x64.7z
        NukeThePeace 1 Reply Last reply Reply Quote 0
        • NukeThePeace
          Tried both versions on my Win10 64bit system. Both came up with "Games found: 0" on any system. Triple checked the right folders.
          • cissou
            cissou last edited by
            There is a little bug on the latests version,
            when used through mono on linux, the gamelist are saved on the roms directory and not inside the system roms directory under the filename "system\gamelist.xml"
            Dell 3020M + X360 sans fil
            Bartop Modulaire : Rpi3
            • johnodon
              johnodon last edited by johnodon
              Sorry...I would post this in the Batocera forum but I do not see a thread for Skraper there.
              Is it possible to add an option to 'Append existing gamelist' (rather than overwrite or update)? Currently, if I set a rom to use a particular emulator (or core), that info is written to the gamelist.xml file. If I then rescrape a system using Skraper, those changes are lost (even if I have it set to 'backup then update').
              Essentially, if a game is already in the XML when you scrape, just pass it over. If the game is not already there, scrape it and append it to the bottom.
              TIA,
              John
                paradadf Staff @johnodon last edited by
                @johnodon there is an option for that, just check the configurations tabs.
                johnodon 1 Reply Last reply Reply Quote 0
                • johnodon
                  johnodon @paradadf last edited by johnodon
                  @paradadf Unless it is somwhere else and I am missing it, the only options I see on the 'Game List' tab are:
                  • No backup, just update existing
                  • Backup existing, then create new
                  • No backup, create new or overwrite existing
                  • Backup existing, then update
                  In my experience, each of the above causes existing metadata that was written to the XML by other means (i.e. 'Edit this game's metadata') to be overwritten.
                  Am I missing something?
                    @johnodon the first or the forth, depending on what you want. “Update” is the keyword.
                    • slakka
                      slakka last edited by
                      Is there a way to change the "Global root folder" so I can run a scrape for ALL SYSTEMS with that altered path? I often play around with multiple boxes at the same time so I like to give them different names, RECALBOX2 etc. The only way I can see to get around this (other than renaming the boxes) is to go into each system change the path and scrape one at a time starting each manually.
                        Hi, a little question concerning Skaper. I'm using beta 7.
                        I recently installed Recalbox6 RC2. I put 2 games (both with a .bin & .cue extensions) in the MegaCD folder. I saw only 2 games in the MegaCD system, even if there were 4 files. Normal. I used the scraper and it scrapped both of the games. But now, 4 files are the MegaCD system (2 are scrapped, 2 are not). Is there a way to scrap a game and to keep hidden the .cue file ? (i know i can hide the file under ES menu if necessary).
                        Thanx !
                        • Bkg2k
                          Bkg2k Staff @Scavy last edited by
                          @scavy adjust the scraped file extensions in the appropriate tab 🙂
                          You can remove the "cue" extention from the list
                            @Bkg2k J'ai enlevé l'extension cue de la liste dans l'onglet"jeux et rom" : résultat skraper se trompe scrape final fight cd avec les infos de point blank sur psx ! Par contre, quand je remets les extensions cue et bin, il passe correctement. J'ai essayé en enlevant le bin et en laissant le cue, mais pas mieux.
                            J'ai testé avec Universal XML Scraper, il passe sans se tromper mais j'aime moins sa finition...
                            Autr chose, j'ai fait un eboot PSX de Legend of Dragoon. Testé en jeu, il fonctionne. Skraper l'a trouvé, créé les sous-dossiers media et stockés les images, fais la gamelist, mais aucune image à l'écran de l'ES. Ca me l'a déjà fait sur d'autres systèmes. Est ce du à quelque chose en particulier ?
                            @elgregou salut, je te réponds ici, c'est dédié à Skraper. Je n'ai pas encore testé, mais à mon avis on doit pouvoir choisir de scraper juste une rom ou plusieurs sans repasser l'ensemble du système à la moulinette ^^
                            elgregou Bkg2k 2 Replies Last reply Reply Quote 0
                            • elgregou
                              elgregou @Scavy last edited by
                              @scavy Merci. J'avais regardé vite fait mais n'avais pas trouvé l'option. Cela dit, cela m'étonnerait aussi beaucoup qu'elle ne soit pas disponible. Je me pencherai dessus un peu plus intensément dès que j'aurai un moment. 🙂
                              • Bkg2k
                                @scavy utilise la dernière version dispo quelques posts au dessus.
                                Le probleme "point blank", du a un changement d'API coté ScreenScraper est réparé depuis longtemps.
                                  Scavy Global moderator @Bkg2k last edited by
                                  @bkg2k Elle est en cours de chargement, j'avais chargé la beta7, mais celle là doit être plus récente. Merci !
                                    Scavy Global moderator last edited by Scavy
                                    Pfff décidemment, 2 jeux pour tester en SegaCD et c'est la cata. Maintenant, il trouve Dune et pas Final Fight lol Mais au moins Point Blank n'est plus la. J'ai noté un truc : quand on supprime le dossier media et la gamelist, puis en rebootant la recalbox (proprement), il arrive que le fichier gamelist.xml ré-apparaisse (le dossier media ne revient pas lui).
                                    Pour la PSX pareil, il ne trouve pas Legend of Dragoon alors qu'il le trouvait avant mais il ne s'affichait pas.
                                    • Gistar
                                      Gistar last edited by
                                      Hello
                                      I tried to scrape my roms but I have this message:
                                      index was outside the bounds of the array
                                      Any idea?
                                      • abunille
                                        abunille @Gistar last edited by
                                        @gistar
                                        Hi,
                                        seems that you reached the limit of requests per day.
                                        With no validated participations the limit is 10.000 requests/day.
                                        • loli72
                                          loli72 last edited by
                                          En ce qui me concerne, j'aimerais bien tester skraper mais chaque tentative de configuration se termine avec ce message d'erreur de Net.Framework!0_1554647650051_skraper.JPG et cela sur mes deux ordinateurs (windows 10 64bits) mis à jour avec la dernière version du Framework (4.7 et des poussières).
                                          J'ai essayer de trouver des infos là dessus sur forum de screenscraper mais accéder au forum en question semble au delà de mes compétences. Je clique sur forum sur leur site et rien ne s'ouvre, donc je me rabats sur ce post.
                                          Auriez vous une idée pour régler ça ?
                                          • Bkg2k
                                            Tu utilises la toute dernière version, dispo quelques posts plus haut?
                                            loli72 2 Replies Last reply Reply Quote 0
