    Recalbox 18.04.20 is out!
    Announcements
    recalbox 18.04.20 out
    22
    46
    48714
    • supernature2k
      supernature2k last edited by supernature2k
      Hi all,
      The memory leak patch is included in this release.
      About the clock, it's a mistake, fix already found.
      It iscurrently gmt time... Oops
      @paradadf it's normal, icons only in select menu, not in any start submenus.
      Glad you like the battery thingy
      Clock won't move from main menu
      I can increase the popup time, current is 3 secs
      Help will be in pop up in next release
      There's an easter egg in this release...
        Substring @nicko last edited by
        @nicko qq unes oui, les idées sont les bienvenues
        • Gaetan
          Gaetan Theme moderator @supernature2k last edited by
          @supernature2k I agree that 3 seconds for the pop up is a bit short, maybe 5 should be fine. Is there a way to modify it by ourselves ?
          Also, maybe it could be great is there will be a possibility to disable the pop up if someone want 🙂
          • trentv8
            trentv8 last edited by
            Hi i was wondering what gpu is supported with this latest recalbox as most games work ok off my older i5 cpu but Nintendo game cube and psp games struggle and lag so i want to add a gpu to fix this so i can play all games on recalbox at 60fps what gpu do you recommend? As i have tryed one 6gb nivida gpu but it didnt work and would not boot into recalbox.
              Substring @trentv8 last edited by
              @trentv8 nothing changed yet regarding x86 supported hardware
              trentv8 1 Reply Last reply Reply Quote 0
              • trentv8
                trentv8 @Substring last edited by
                @substring oh ok is there a list of gpus that have been tested that works? As i dont want to go out and buy a unsupported gpu? Cheers
                • ernsmaniac
                  ernsmaniac last edited by
                  ok so new to recalbox. I am running on old desktop via usb drive. I tired update and it froze. I reinstalled new version and now status is not connected even though I am using an Ethernet cable. also not showing any other storage devices which I have all my roms on separate usb stick. any ideas? not super tech savvy either
                    Substring @ernsmaniac last edited by
                    @ernsmaniac please make your own topic
                    • lackyluuk
                      @supernature2k Thanks for the answers 🙂 i really like the pop ups. They give a modern look & feel.
                      Can you cofirm as well the following thing?
                      This is maybe a bug: If I go to advanced settings and i move to the VRAM settings, the cursor just move further, just like I would keep my button pressed. It happens only on the vram entry in both directions.
                      supernature2k 1 Reply Last reply Reply Quote 0
                      • supernature2k
                        supernature2k @lackyluuk last edited by
                        @lackyluuk looks like this is a bug, working on it!
                        • nwildner
                          nwildner last edited by
                          Don't know if this is a bug that requres a new topic, or just a little usability issue that the devs could be already tracking 🙂 . The new battery indicator shows the battery of the last controller connected:
                          • Connected Player1 through bluetooth = 50% battery is shown;
                          • Connected Player2, that has more battery = 75% battery is now shown, replacing the current icon;
                          And again, thanks for this wonderful release 🙂
                          PT_BR Retrogaming on Telegram
                          • supernature2k
                            supernature2k @nwildner last edited by
                            @nwildner whaaaaaat ? On which board?
                            Thisbis supposed to show laptop battery level, not controllers
                            nwildner 1 Reply Last reply Reply Quote 0
                            • nwildner
                              nwildner @supernature2k last edited by nwildner
                              @supernature2k Raspberry Pi 3. And it is showing the controller battery as i described above 🙂
                              I took a look at the EmulationStation code and read SDL_GetPowerInfo, and it does not seems to handle "multiple batteries" neither identify what kind of battery is being used through /sys dev filesystem. Maybe that's why i have this behavior that, the last controller connected is shown as battery inside the menu(and of course, PS3 batteries have some issue of not being recognized as SDL_JoystickPowerLevel for some weird reason).
                              • supernature2k
                                @nwildner thx for the feedback !
                                You are right, SDL has strange behavior and this battery indicator was meant for batteries in laptop.
                                We will restrain this to x86 as it was the arch it was made for.
                                • nwildner
                                  @supernature2k
                                  And what about PCs using PS3 clone controllers? It will be the same: Last controller connected will be the battery shown at the menu 😉
                                    Substring @nwildner last edited by
                                    @nwildner (i've been telling him for days .... Shhhhhh ...)
                                    • supernature2k
                                      supernature2k @Substring last edited by
                                      @substring nope it won't with the new way I'm handling this 😉
                                      • nwildner
                                        @supernature2k And why dont you extend this method to map PS3 controllers batteries ? 😄
                                        A while ago, before 4.1 started to change my way to contribute with Recalbox i has helping to test PES features, and one of them was PS3 Controllers battery - https://github.com/neilmunday/pes/issues/29 . Getting the contents of /sys/class/power_supply/sony_controller_battery_<BT_MAC_ADDRESS>/capacity should be enough(using bluez) to extend your Recalbox Battery API to this kind of controller.
                                        What do you think? (rolls a d20 and quietly exits the tavern while creating a request)...
                                        • 2Dsx
                                          2Dsx @rockaddicted last edited by
                                          Nice work guys! Looks very nice.
                                          @martin-steiner said in Recalbox 18.04.20 is out!:
                                          Nice work guys. The only things that keeps me from migration is the lack of videosnaps. I don't understand that... Why?
                                          What do you mean? Do not have plans to support videosnaps? Sorry for the English, I speak Spanish
                                          • zeoboromir
                                            zeoboromir last edited by
                                            I have a speed issue with this update, all games run slow, any solution?, y update from raspberry pi 3...
