    Left and right not working on fba_libretro
    left right fbalibretro
    6
    12
    5229
    • 0zzy
      0zzy last edited by 0zzy
      Hi, i have the last recalbox version.
      If i try to play arkanoid or chase hq, out run, on fba_libretro, i can't go left and right with the keyboard (other games are ok)..why?
      paradadf voljega barbudreadmon 3 Replies Last reply Reply Quote 0
        paradadf Staff @0zzy last edited by
        @0zzy because they probably had analog input devices which are mapped to either the left or right analog stick.
          voljega Banned @0zzy last edited by
          @0zzy Recalbox is not meant nor configured to be used with keyboard anyway, you need a gamepad.
          • 0zzy
            0zzy last edited by
            @voljega y are right, keyboard is not the best controller, but i'm testing it
            @paradadf: if i use a ps2 controller i think i could move in both directions but in my final setup i will use gpio with arcade buttons, so how can i reconfigure them?
              @0zzy said in Left and right not working on fba_libretro:
              all I'm saying is keyboard might simply not work where a gamepad would
              0zzy 1 Reply Last reply Reply Quote 0
              • 0zzy
                0zzy @voljega last edited by
                @voljega if i don't have a gamepad but an arcade control panel? i'll check
                • barbudreadmon
                  barbudreadmon @0zzy last edited by
                  Original hardware had a wheel, don't expect to play them properly with a d-pad. I would recommend to either find a way to have analog controls in your setup or drop games using those controls (most of them are racing games but there are a few exceptions like arkanoid or after burner)
                  Libretro developper :
                  • FBAlpha FBNeo (Arcade)
                  • Kronos (Sega Saturn/ST-V)
                  • YabaSanshiro (Sega Saturn)
                  • 0zzy
                    0zzy @barbudreadmon last edited by
                    @barbudreadmon you are right, but if the same game works in mame, why not let it work also on fba_libretro.
                    i'm trying to marge these 2 systems, i don't want both, but some roms for wich controls works on mame, does not work at the same way on fba
                    • barbudreadmon
                      barbudreadmon @0zzy last edited by barbudreadmon
                      Because that's not possible, fba doesn't have an internal osd to configure inputs like mame, so i have to define the best possible default controls and let the user use "Quick Menu > Controls" if he wants to change them within the limitation (retroarch won't allow changing from analog to digital, neither the reverse).
                      Anyway i don't really understand your point, you are basically saying that since mame allows inept controls for a game, fba has to allow it too. Should i add mouse support for platformers then ? I'm pretty sure mame allows it.
                      • 0zzy
                        @barbudreadmon said in Left and right not working on fba_libretro:
                        Because that's not possible, fba doesn't have an internal osd to configure inputs like mame, (retroarch won't allow changing from analog to digital, neither the reverse).
                        Ah ok, thanks!
                        • Dragu
                          Dragu Banned last edited by
                          I read that there is a bug in kernels 4.4-4.8 that messes up the analog axes. The d-pad works as intended though.
                          • Sylluck
                            Sylluck last edited by
                            Adding this to your CFG controller file should fix the problem:
                            input_l_y_minus_axis = "-1"
                            input_l_x_plus_axis = "+0"
                            input_l_y_plus_axis = "+1"
                            input_l_x_minus_axis = "-0"
