    Mame 2010 recalbox 18.02.09
    Emulator Arcade/PC/Console
    mame 2010 recalbox 18.02.09
    6
    15
    6507
    • newnetcity
      newnetcity last edited by
      hi
      I ve got some issues with mame 2010 on the last recalbox update.
      CPS2 games runs full screen by default and it’s impossible to remap controller with mame 2010
      is it normal?
      thanks
        Substring @newnetcity last edited by
        @newnetcity not all cores support core remapping. I can't tell for mame2010, but this could be the case
        • newnetcity
          thanks for your quickly reply
          I think it s the case with mame 2010.
          • Ernest Brown
            Ernest Brown last edited by
            Mame 2010 is broken (in some kind). Second player controller is loosing a part of its buttons (in XBOX its B and R1). 2 buttons from 6 functional are not working. Directional and start/select are ok.
              @newnetcity cores that have their own menu don't need core remapping. I haven't tried mame2010, but mame2003 has a menu, so i'd say the same goes for mame2010
              • Ernest Brown
                on mame2003 and others cores/emulators (and in the system) i have no problems, all buttons are working correctly
                • markwkidd
                  markwkidd last edited by
                  I recently updated the input code for mame2010. It now supports four players and standard retroarch input remapping. These features may not have made their way to the recalbox version yet, but they will the next time the core is updated on this side.
                  voljega Ernest Brown 2 Replies Last reply Reply Quote 2
                    voljega Banned @markwkidd last edited by
                    @markwkidd also OP is right all CPS1 and CPS2 games are deformed, and a few others two
                    • markwkidd
                      markwkidd last edited by markwkidd
                      I don't know about the CPS1/CPS2 error and it is not logged yet on github: https://github.com/libretro/mame2010-libretro/issues
                      If the mame2010 core is updated in recalbox and there is still a bug with CPS, please submit a new github Issue and include a log.
                        @markwkidd said in Mame 2010 recalbox 18.02.09:
                        do you really need a log ? it's just that the game appears deformed on screen ... I will do two screenshots mame2003 / mame2010 of the same game to show the problem and then log an issue
                          Substring @markwkidd last edited by
                          @markwkidd in fact there is one https://github.com/libretro/mame2010-libretro/issues/20
                          markwkidd 1 Reply Last reply Reply Quote 1
                          • markwkidd
                            markwkidd @Substring last edited by
                            @substring said in Mame 2010 recalbox 18.02.09:
                            Ah hah, thanks for clearing that up for me.
                            • Ernest Brown
                              Ernest Brown @markwkidd last edited by Ernest Brown
                              @markwkidd is there a way for an user to fix it? or we have to wait for a next update?
                              (i'm thinking about the mame 2010 input)
                                acris @Ernest Brown last edited by
                                @ernest-brown said in Mame 2010 recalbox 18.02.09:
                                yes
                                Ernest Brown 1 Reply Last reply Reply Quote 0
                                • Ernest Brown
                                  Ernest Brown @acris last edited by
                                  @acris said in Mame 2010 recalbox 18.02.09:
                                  yes
