    PS4 controller causes problems in Kodi
    MediaCenter & Dualboot
    ps4 causes kodi
    6
    8
    3835
    • hitmaker
      hitmaker last edited by hitmaker
      PS4 controller works without a problem for emulators but whenever I launch Kodi with the controller connected after half a minute or so it causes Kodi to freeze and it can't be used to navigate anymore (sound stutters and it acts like a button is kept on being pushed repeatedly)
      The moment I disconnect the ps4 controller there is no problem at all.
      Tried with wii remote and no problem in Kodi, it must be a problem with DS4 controllers I guess.
      Is this a known problem ?
      • marvto
        marvto last edited by
        Hello,
        i have the same problem, anybody has a solution?
        Greets
          Hi !
          does this happen over USB or BT ? @acris @supernature2k can you confirm ?
          keltac 1 Reply Last reply Reply Quote 0
          • keltac
            keltac @Substring last edited by
            @substring
            i have the same problem ... with USB or BT ...
              @Substring i dont use kodi neither ps4 controller.
              • marvto
                marvto last edited by marvto
                Hi @Substring
                over BT.
                • Jefferymoore
                  Jefferymoore last edited by Jefferymoore
                  Not really sure but does there seem to be anything wrong with the controller? Do the analog sticks work fine for you?
                  But for me it works fine outside of Kodi as far as I can tell.
                    I won't resolve this problem as kodi 17 will make things a lot easier
