    Need help about power source
    Emulator Arcade/PC/Console
    need help source
    • Alejandro Sánchez
      Alejandro Sánchez last edited by
      Hi, since i had no answer in a previous post, i now have to post it again, i have a Raspberry pi 3 working with a power source of 2A, and i know that the minimum is 2.5A. my question is: if i upgrade the power source, say 3A, will i have more performance in emulators such as psp, psx and nintendo 64? Please forgive my english
      lackyluuk 1 Reply Last reply Reply Quote 0
      • lackyluuk
        lackyluuk Translator @Alejandro Sánchez last edited by
        @alejandro-sánchez Hello 🙂
        Actually it doesn't matter. As long as you don't face a colored square or a yellow lightning in the upper right corner of your display the RPi has enough power to run fullspeed. The hardware itself limits the performance, not only the power you provide.
        Alejandro Sánchez 1 Reply Last reply Reply Quote 0
        • Alejandro Sánchez
          Alejandro Sánchez @lackyluuk last edited by
          @lackyluuk what does it mean if i do see the colour square or the lightning (beside the fact that i dont have enough current)??
          • abunille
            abunille @Alejandro Sánchez last edited by abunille
            @alejandro-sánchez
            Hi,
            how @lackyluuk said, the hardware limits the perfomance itself, but undervoltage can also makes problems with performance, lags, issues (maybe not much, but it does).
            https://www.raspberrypi.org/documentation/configuration/warning-icons.md
