    N64 Gamepad and Libretro Glupen64 (4.1)
    GamePad/GPIO/USB encoder
    gamepad libretro glupen64 4.1
    4908
    • TheMadcore
      TheMadcore last edited by
      Libretro Glupen64 is my weapon of choice to emulate Nintendo 64 on Recalbox. But mapping a "N64" USB gamepad is taking me a hell of a work.
      The main problem I have is to find a way to separate the C buttons from the A and B buttons and map them then.
      Anyone knows how can I achieve that?
      Alanna López 1 Reply Last reply Reply Quote 0
      • lackyluuk
        @TheMadcore I know the following article is not about glupen, but maybe it can help in some way?
        https://forum.recalbox.com/topic/9016/a-lire-manettes-n64
        TheMadcore 1 Reply Last reply Reply Quote 0
        • TheMadcore
          TheMadcore @lackyluuk last edited by
          @lackyluuk thanks. I already tried that before moving from mupen64plus to libretro glupen64, but didn't work.
            Substring @TheMadcore last edited by
            @themadcore have you give a try to core remap ? no idea if it works in glupen ...
            • TheMadcore
              TheMadcore @Substring last edited by
              @substring yes (if you mean the input config on the quick menu). The options are limited to what I tell, mergin the left and down C buttons with B and A buttons. There's no option to have the C buttons completely separate from the rest.
              I know the core have this to accommodate them well to a modern gamepad, where you can have the C buttons on the second joystick, or activate them with a trigger. But make it really difficult to map a real or faux USB N64 gamepad.
              Anyway, I know this is something the Recalbox team can't do very much about it, because is something core related. Looks like there's a core option in one of the other n64 cores on PC to have the C buttons mapped separated, but this option isn't on glupen.
              Anyway, thanks for the help and your time.
                @themadcore on a side note, you could eventually try parallel64 on your PC and check if it does have that remapping option. If it's worh we may add it
                • Alanna López
                  Alanna López @TheMadcore last edited by
                  @themadcore how do you even make it work? (the libretro core), every game crashes on boot for me, I believe mario party 2 works with th Glupen64, but it won't stop crashing 😞
                  • TheMadcore
                    TheMadcore @Alanna López last edited by
                    @alanna-lópez I only chose Libretro as emulator and Glupen64 as core as the default Nintendo 64 emulator on the advanced options. Don't have any problem running games after that. Did this on a Pi2 and a Pi3.
                    @Substring there it is:
                    And works like a charm.
                      @themadcore that's parallel64 ?
                      • TheMadcore
                        @substring yes. You can see on the screenshots in the lower left corner that parallel is the loaded core.
                          @rockaddicted what do you think about adding parallel64 ?
