    Need your help to translate a tool !
    Recalbox general
    need help translate tool
    2776
    • NeeeeB
      NeeeeB last edited by
      Hi !!
      Sorry to hijack this forum but I've built a little tool, a GameList Editor which can be useful for all of us.
      Here it is :
      https://forum.recalbox.com/topic/9265/soft-gamelist-editor
      Now I'm looking for some nice people to localize it to various languages.
      So if you think you can help me with it, go ahead, the PoEditor project is here :
      https://www.poeditor.com/projects/view?id=137171
      There are "only" 104 strings to translate.
      And feel free to add other languages if you can translate to another !!
      Many thanks for your help.
      Vieux geek ^^
      uzanto 1 Reply Last reply Reply Quote 0
      • uzanto
        uzanto @NeeeeB last edited by uzanto
        @neeeeb I'm translating it.
        I don't understand the meaning of this
        "Remove region from games names"
        I can translate it literally and someone can fix it on future because I'm never used your software and I don't know to which it refers.
        "Disable Pi prompts" sounds weird in Spanish I translated it like "Disable Raspberry prompts"
        NeeeeB 1 Reply Last reply Reply Quote 1
        • NeeeeB
          NeeeeB @uzanto last edited by
          @uzanto
          Great many thanks, I've seen your progress on PoEditor.
          It means " remove the region tag that can be sometimes in the name of the game after scraping"
          Example : "Super Mario World [Europe]"
          It will remove the [Europe] part from the name 😉
          Vieux geek ^^
          • uzanto
            @NeeeeB everything is done, waiting for some corrections if anyone wants.
            NeeeeB 1 Reply Last reply Reply Quote 0
            • NeeeeB
              @uzanto
              Thank you very much, I will add your translation as soon as possible, and credit you in the About window as a translator 😉
              If someone needs to correct anything, no problem, do it on PoEditor and I will be notified 😉
              Thx again uzanto, really appreciated !!
              Vieux geek ^^
              • lackyluuk
                @NeeeeB German is also done with help of @gmgman
                • NeeeeB
                  NeeeeB @lackyluuk last edited by
                  @lackyluuk
                  Saw it, and fixed the small typo you mentioned in the comments.
                  Many thanks to you too, you are both already credited in my local version, will make it available to everyone sson !!
                  Really appreciated !!
                  Vieux geek ^^
