    Solved Tips and Suggestions Wanted
    tips suggestions wanted
    4094
    • dh04000
      dh04000 last edited by
      Hello Recalbox group & my favorite @Substring
      I recently got a kickstarter called the Raspiboy which has a 320x240 pixel composite screen, and uses gpio audio.
      Here's a forum post with the settings I am using http://forum.8bcraft.com/viewtopic.php?f=2&t=1368
      Is there any mods to the emulator software that you'd suggest to get the "best" performance on games (considering the screen size, ie: rendering to over 320x240 wouldn't make sense just to downscale again)? Or am I prefect as is? How about psx games, as some "kinda work" on the raspberry pi zero. What is it's default rendering size, and could I change this to eek out a bit more performance?
      Thank you
        paradadf Staff @dh04000 last edited by
        @dh04000 what about this?
        https://forum.recalbox.com/topic/8678/tuto-installing-recalbox-on-the-8-b-craft-raspiboy/
        dh04000 1 Reply Last reply Reply Quote 0
        • dh04000
          dh04000 @paradadf last edited by
          @paradadf said in Tips and Suggestions Wanted:
          That's the same guide that is on the 8bcraft forum, that I followed. I was just curious if there was anything else that could be tuned.
            @dh04000 by setting the global.videomode to default you are outputing to the screens resolution, so there is nothing else you can do.
            • dh04000
              dh04000 @paradadf last edited by dh04000
              @paradadf Great, thats what I wanted to know. Thank you, I'll mark this as solved.
              EDIT: I can't figure out how to mark it.
                Substring @dh04000 last edited by
                @dh04000 eventually force progressive mode by adding sdtv_progressive_scan=1 in the config.txt (something i've been discussing on IRC with @screech )
                • dh04000
                  dh04000 @Substring last edited by
                  @substring said in Tips and Suggestions Wanted:
                  @Substring
                  That setting made the screen really blurry.
                    @dh04000 the screen just sucks ... Is it a pal or ntsc screen ?
                    dh04000 screech 2 Replies Last reply Reply Quote 0
                    • dh04000
                      No idea.
                      Screen SKU: LQ035NC111
                      Where to buy it page: http://www.buydisplay.com/default/3-5-inch-tft-lcd-color-module-in-320x240-touch-screen-lq035nc111
                      Datasheet: http://www.buydisplay.com/download/manual/ER-TFT035-3_Datasheet.pdf
                      • screech
                        screech @Substring last edited by
                        @substring 240P NTSC 😉
