    Waveshare 3.2" display issue
    waveshare display screen tft
    4519
    • Luny Calvin
      Luny Calvin last edited by
      Hello everyone,
      I have been struggling for hours with my new waveshare display that I ordered especially because I knew it would be compatible with recalbox.
      I followed everything on the wiki page :
      • Download, rename and copy the dtb files to waveshare32b.dtbo and waveshare35a.dtbo to /boot/overlays
      • Edit the /boot/config.txt file to add the information from the wiki at the end of the file
      • Download the fbcp file and copy it to /usr/bin after fixing the permissions
      And I still end up with a white screen 😞
      HDMI works perfectly and the resolution is 320x240 as expected. What did I miss?
      I looked everywhere for an answer, but no luck.
      Thanks for your help!
      • abunille
        abunille @Luny Calvin last edited by abunille
        deleted sorry , wrong display
          You need to edit recalbox.conf
          Modifiy the ̀recalbox.conf` file like :
          #global.videomode=DMT 87 HDMI
          global.videomode=default
          #global.ratio=auto
          global.ratio=4/3
          Save the file, and reboot. The screen should now work perfectly. If you encounter some problems, first check that the fbcp program is running with :
          ps aux | grep fbcp
          https://github.com/recalbox/recalbox-os/wiki/TFT-Screen-SPI-Bus-(EN)#configure-your-waveshare-32-resistif-tft-screen
          Luny Calvin 1 Reply Last reply Reply Quote 0
          • Luny Calvin
            Luny Calvin @acris last edited by
            @acris Thanks for your answer, but the screen is still white 😞
            I had already modified the file, and fbcp outputs this in the log file :
            RECALBOX user.info fbcp[599]: Primary display is 320 x 240
            RECALBOX user.err fbcp[599]: Unable to open secondary display
            I guess I will have to way for the 4.1 unstable update to be back online, but I would really like to know what I missed 😕
              @Luny-Calvin
              are you make this file ?
              Create a new file named S11fbcp in /etc/init.d/ :
              #!/bin/sh
              case "$1" in
                      start)
                              printf "Starting fbcp ... "
                              start-stop-daemon -S -q -m -b -p /var/run/fbcp.pid --exec /usr/bin/fbcp -- -n
                              echo "done."
                      stop)
                              printf "Stopping fbcp ..."
                              start-stop-daemon -K -q -p /var/run/fbcp.pid
                              echo "done."
                      restart)
                              $0 stop
                              sleep 1
                              $0 start
                              echo "usage: $0 {start|stop|restart}"
              esac
              i think you passed a step
              • Download, rename and copy the dtb files to waveshare32b.dtbo and waveshare35a.dtbo to /boot/overlays + chmod 777
              • Create a new file named S11fbcp in /etc/init.d/ + chmod 777
              • Edit recalbox.conf
              make : ps aux | grep fbcp and post result
              and you need to :
              • install recalbox 4.0.1 official on microsd on TV HDMI
              • update 4.0.1 ->4.0.2
              • use recalbox theme
              https://github.com/recalbox/recalbox-os/wiki/Recalbox-support-(EN)
              @ian57 any idea ?
              • Luny Calvin
                @acris
                I did create the S11fbcp file but I didn't change the permissions for the dtbo files !
                I will try this this evening (I just got to work and I already want to leave :P)
                • Luny Calvin
                  Luny Calvin @Luny Calvin last edited by
                  @acris
                  Still nothing, always a white screen even with chmod 777.
                  ps aux | grep fbcp gives:
                    633 root     grep fbcp
                  Here is my config.txt file:
                  # uncomment if you get no picture on HDMI for a default "safe" mode
                  #hdmi_safe=1
                  disable_overscan=1
                  # uncomment to force a specific HDMI mode (this will force VGA)
                  #hdmi_group=1
                  #hdmi_mode=1
                  # comment to get jack audio
                  hdmi_drive=2
                  config_hdmi_boost=0
                  # force hdmi while the tv can take time before sending the signal on the hdmi output
                  #hdmi_force_hotplug=1
                  # uncomment for composite PAL
                  #sdtv_mode=2
                  # uncomment for lirc-rpi
                  #dtoverlay=lirc-rpi
                  # if you plug your tv at the same time as your rpi and that the rpi switches from the hdmi or give a low resolution because tv had no enough time to initialize it
                  boot_delay=3
                  # uncomment if you don't want the rainbow at startup
                  disable_splash=1
                  # Overclock
                  gpu_mem_256=128
                  gpu_mem_512=256
                  gpu_mem_1024=512
                  avoid_safe_mode=1
                  kernel=zImage
                  #Waveshare 3.2 TFT Screen
                  #same resolution for hdmi and tft
                  hdmi_cvt=320 240 60 1 0 0 0
                  hdmi_group=2
                  hdmi_mode=1
                  hdmi_mode=87
                  dtparam=spi=on
                  dtoverlay=waveshare32b:rotate=270,speed=82000000
                  And the file permissions for the overlays:
                  -rwxr-xr-x    1 root     root          2354 Aug  2 21:36 waveshare32b.dtbo
                  -rwxr-xr-x    1 root     root          2682 Aug  2 21:36 waveshare35a.dtbo
                  fbcp still outputs the same thing in the log file.
                  Here is the archive from the recalbox-support script: http://dl.free.fr/rluEHn909
                  fs 1 Reply Last reply Reply Quote 0
                  • fs
                    fs @Luny Calvin last edited by
                    @luny-calvin This is 755, not 777.
                    • Luny Calvin
                      Luny Calvin @fs last edited by
                      @fs
                      You're right! But the /boot/overlays folder is on a FAT32 partition, so I can't change the permissions. But r-x should be enough, right?
