    Recalbox not recognizing 2nd player 03H Dual Arcade 3...
    GamePad/GPIO/USB encoder
    recalbox recognizing 2nd player 03h
    7787
    • Andrei
      Andrei last edited by
      Hello,
      i am working on a arcade coffee table project.All fine until now but i cannot set up the 2nd player.
      Controllers are recognized as 03H Dual Arcade 3... and al buttons are connected to one usb controller.
      Any ideas?
      • Andrei
        I found this.
        recalbox-buildroot/board/recalbox/fsoverlay/etc/modprobe.d/usbhid.conf
        3H Dual Arcade 2Players
        options usbhid quirks=0x16c0:0x05e0:0x040
        How can i access the usbhid.conf ? so i can add 2 players
          Hello @Andrei
          only it usbhid is the same encoder
          and this syntax is only for 4.1
          You need to check this information in dmesg log
          if you have recalbox 4.0.2
          https://forum.recalbox.com/topic/4630/mapped-2p-buttons-don-t-behave-correctly/6
          Andrei 1 Reply Last reply Reply Quote 0
          • Andrei
            Andrei @acris last edited by
            Hi @acris
            Thanks for your reply.
            so i delete and added this line :
            dwc_otg.fiq_fix_enable=1 sdhci-bcm2708.sync_after_dma=0 dwc_otg.lpm_enable=0 console=tty3 loglevel=3 elevator=deadline vt.global_cursor_default=0 logo.nologo root=/dev/mmcblk0p7 rootwait fastboot noswap ro usbhid.quirks=0x16c0:0x5e1:0x040
            still nothing, i see only Player 1 on #0 and nothing like #1
              I need your recalbox- support.sh.
              Check wiki.
              • Andrei
                i updated to 4.1, trying like this...
                • Andrei
                  Andrei last edited by Andrei
                  I have the same problem like this guy.Also my encoder is same.looks that he solve it.Can someone help me solve the problem?
                  I added usbhid quirks=0x16c0:0x05e0:0x040 , but sill no luck
                  https://forum.recalbox.com/topic/6148/encodeur-usb-joystick-2-joueurs-3h-equivalent-xim-mo-impossible-2players/2
                  I get this:
                  /recalbox/scripts/recalbox-support.sh
                  lspci: /sys/bus/pci/devices: No such file or directory
                  /recalbox/scripts/recalbox-support.sh: line 53: aplay: command not found
                  /recalbox/scripts/recalbox-support.sh: line 54: glxinfo: command not found
                  /recalbox/share/saves/recalbox-support-20170317152936.tar.gz
                  https://file.ac/Z7mRFq-rubk/
                    In recalbox 4.1, your encoder works. you didn't need to modify something.
                    delete usbhid quirks=0x16c0:0x05e0:0x040 added.
                    you need to mapp your joystick and buttons in emulationstation menu only player 1
                    • Andrei
                      Still not working :S
                      i installed fresh recalbox with updates to 4.1
                      https://file.ac/bM5uh6Yd7xk/
                      I am thinking to connect 2nd player to Pi GPO ...it will work?
                        @Andrei
                        Post your cmdline.txt too
                        you need to connect all joystick and buttons on your usb encoder.
                        • Andrei
                          all mjoysticks buttons are connected, #1 and #2 in mirror.
                          • Andrei
                            sadly i could't fix it so i connected 2nd player to pi gpio.thx for help
                            • RebeccaRGB
                              RebeccaRGB last edited by
                              I fixed this by editing boot.ini and adding usbhid.quirks to this line:
                              setenv bootargs "${bootrootfs} ${console}"
                              like so:
                              setenv bootargs "${bootrootfs} ${console} usbhid.quirks=0x16c0:0x75e1:0x040"
                              I know this topic is old but I was having this same problem with recalbox 17.12.02 and this was the top Google result for "recalbox 3h dual arcade".
                                Substring @RebeccaRGB last edited by
                                @rebeccargb don't necro such annold topic ... You're using an odroid, not a pi. Boot confg files and syntax are quite different
                                • Andrei
                                  Fixed with Recalbox release: 18.03.16
                                  Thank you
                                  • JHaleIT
                                    JHaleIT last edited by JHaleIT
                                    Sorry to bring up an older post, but I have the same issue with a different product ID. I found information about it, but it's in Chinese..
                                    I have no clue what it all means.. lol I'm on x86 version of Recalbox..
                                    Up and left on both joysticks refuse to work..
                                    https://www.tipga.com/e/59cfad8a3286fe2a4ac123c8
                                    • JHaleIT
                                      Any update with this?
                                      • JHaleIT
                                        More information here: https://retropie.org.uk/forum/topic/7832/fix-up-left-joystick-direction-for-tht-2p-arcade-controller-with-device-id-0x75e1
                                        but it's for Retropie.. I'm using x86/x64 version and ID information: 0x16c0:0x05e0:0x040
                                        • JHaleIT
                                          There's a patch file I found that fixes the problem, but how do I apply it?
                                          Here is the patch: http://ithink.ch/blog/files/xin-mo/0001-hid-Add-new-driver-for-non-compliant-Xin-Mo-devices.patch
                                          100.8k
