    Black screen using HDMI2VGA
    hdmi2vga
    4522
    • xphere
      xphere last edited by xphere
      Hi all,
      I'm using one HDMI2VGA converter (a standard model from a known Chinese shop), but I cannot make it work...
      I've tried the converter with a laptop and it works, so I discard that the converter has any defect.
      Then, I've tried all possibe config.txt combinations... but I always get black screen in the TFT... the options that I've modified are:
      #for forcing VGA mode to 640x480-60Hz:
      hdmi_group=2
      hdmi_mode=4
      #for enabling HDMI
      hdmi_safe=1
      #comment to get jack audio (i've read that in some converters this is required, despite my
      #converter has no audio output)... I've tried commenting, setting it to '1' and '2'... no luck!
      hdmi_drive=2
      #I've tried with 0 (default) and 4 (which is supposed to give more "power" to the TFT)
      config_hdmi_boost=4
      hdmi_force_hotplug=1
      Any other Idea? I am missing any configuration parameter?
      Anyone that has a HDMI2VGA converter working, could please post the config.txt file?
      Thanks a lot!!!!
        paradadf Staff @xphere last edited by
        @xphere I recommend you to test the same adapter with a laptop and that screen. I bought one that only worked with the output of my little camera, but couldn't handle higher resolutions, so it was useless.
        • xphere
          Hi paradadf! Thanks for replying!
          Yes, I've tried with the laptop and the same TFT screen that I've used with the raspberry, and I've been able to set up a resolution up to 1680x1050 (60Hz) (the maximum supported by the TFT), so I assume that the TFT is also working...
          I have even tried with the "hdmi_ignore_edid" option, to ignore edid info, but still same results...
          hdmi_ignore_edid=0xa5000080
          paradadf Substring 2 Replies Last reply Reply Quote 0
            paradadf Staff @xphere last edited by paradadf
            @xphere I don't know, but @ian57 probably does! 😄
              Substring @xphere last edited by
              @xphere not even noobs displays anything ?
              • xphere
                I've tried all possible options and none seems to work... Even noobs is not displaying anything... 😞
                it's strange because I've seen on forums and youtube videos that my adapter works on rpi! but none of the options worked for me.
                • idarius
                  idarius last edited by
                  hi, here is my config for 240p on my crt with hdmi => vga :
                  hdmi_pixel_encoding=2
                  avoid_safe_mode=1
                  disable_overscan=1
                  config_hdmi_boost=4
                  hdmi_drive=2
                  hdmi_group=1
                  hdmi_mode=6
                  hdmi_force=1
                  kernel=zImage
                  gpu_mem_256=128
                  gpu_mem_512=256
                  gpu_mem_1024=512
                  avoid_safe_mode=1
                  disable_splash=1
                  dtparam=audio=on
                  xphere 2 Replies Last reply Reply Quote 1
                  • xphere
                    xphere @idarius last edited by
                    @idarius thanks for the reply! I will try that configuration! eventhough, it sounds strange to me that you have tried the CEA mode:
                    # this is for HDMI_CEA_480i60
                    hdmi_group=1
                    hdmi_mode=6
                    If you are using a VGA monitor, should not be better to use a DMT mode?
                    # this is for HDMI_DMT_VGA_60 (640x480)
                    hdmi_group=2
                    hdmi_mode=4
                    • xphere
                      xphere @idarius last edited by xphere
                      @idarius by the way... what does this parameter in your config do?
                      hdmi_force=1
                      I've not found any documentation related, probably you mean "hdmi_force_hotplug=1"? (you already have this parameter repeated twice in your config)
                      Thanks!
                      • idarius
                        yeah i think it's a mistake for the hdmi force 1, i seen it on some forum.
                        For the hdmi mode 6 group 1, its because on a crt i need 480 i. talked about crt tv, not crt pc screen, so resolution is 240p max or 480interlaced.
                        my games run in 240p (320 x 240), but EmulationStation is unreadable with this resolution, so ==> 480i 🙂
                        xphere 1 Reply Last reply Reply Quote 0
                        • xphere
                          @idarius Thanks for the explanation.
                          I've tried your code but... no luck! I'm always getting no signal on my TFT (LG 19inch L1953S-SF).
                          • xphere
                            I have found the solution!!!!!!!!!!!!!!!!
                            The problem was not in the converter, neither in the configuration!
                            The problem was due to this!!! the fu**ing hdmi wall mount that I have in the box that contains the rpi was cutting the VGA signal, so I tried to connect the HDMI2VGA adapter directly to the rpi, instead of the wall mount and... voilá! works perfectly!!!! even detects automatically the resolution!!!!
                            so.. conclusion: DO NOT USE ANY CABLE BETWEEN THE HDMI OUTPUT AND THE HDMI2VGA CONVERTER!!!!!!
                            • idarius
                              hehe cool for you, pretty weird 🙂
