    [4.1-Unstable] Bug reports
    4.1 bugs
    46
    349
    423354
      I'll update the 1st post with known issues
      • lackyluuk
        @Substring the credits for the solution of the absence of the scrapes goes to @acris 🙂
        I just added it here to the english thread
        • dewen
          dewen last edited by
          PCSX_REARMED can not play Zanac x Zanac --> Zanac Neo, freeze at memory card check.
          It is the PCXS_REARMED version problem, old version ( recalbxo 4.0 use it ) can play it.
          kelv 1 Reply Last reply Reply Quote 0
          • treacle
            treacle @Substring last edited by treacle
            @Substring Just realized, that I still had my USB BlueTooth dongle plugged in. Removed it and rebooted to try the internal BlueTooth. Now I can't connect my PS3 controller via BlueTooth. Works with the cable though. Oh, and I pressed the little button at the bottom to reset the controller.
            Is there anything I need to set in the conf?
              Substring @treacle last edited by
              @treacle you need to reset your pad as bluez5 manages pairing according to the BT dongle MAC address. So you can't switch from one dongle to another without repairing.
              plus your PS3 pad knows its master mac address, so it wouldn't connect to the internal bt
              treacle 1 Reply Last reply Reply Quote 0
              • ferminote
                ferminote last edited by
                At the start, when the new start screen is displayed the sound is VERY HIGH, I would say 100%. Once the menu appears, it is adjusted to what we have adjusted.
                Also it would be well that the volume of the background music of the menu can be regulated independently to the one of the games, since the music of the menu is higher than the one of the games.
                thanks!!!!
                sorry for my english
                ferminote Substring 2 Replies Last reply Reply Quote 0
                • ferminote
                  ferminote @ferminote last edited by
                  @ferminote
                  [url=http://subefotos.com/ver/?95ab49bc1f1591a670fc660332c0b449o.png][img]http://thumbs.subefotos.com/95ab49bc1f1591a670fc660332c0b449o.jpg[/img][/url]
                    Substring @ferminote last edited by
                    @ferminote your english is fine 🙂 The fact is that the sound volume is at default at this moment and has not yet been set to what users defined it in ES
                    • treacle
                      @Substring I did reset my pad (pressed the button at the back with a pin). And I selected Delete BlueTooth controller (or what it's called) in the menu in ES. When I then try to add BT controller in the menu, it doesn't find it...
                      My understanding was that PS3 controllers are automatically added as BT device after pairing via cable, right?
                        Need to edit recalbox.conf to change driver
                        controllers.ps3.enabled=1
                        ## Choose an driver between official, shanwan and gasia if you have dualshock clones (official,shanwan,gasia)
                        controllers.ps3.driver=bluez
                          voljega Banned @acris last edited by voljega
                          @acris just curious but does this mean that from now on (4.1+) every ps3 pad (official, shanwan and gasia included) should use the bluez driver ?
                            Substring @voljega last edited by
                            @voljega
                            original is required for gasia, should also work with genuine
                            bluez works for shanwan and genuine
                              @treacle said in [4.1-Unstable] Bug reports:
                              Yep, DualShock3 don't follow a regular pairing process (whereas DS4 do). You don't pair through ES with DS3
                              • Juan Carlos Leal Payá
                                Juan Carlos Leal Payá last edited by
                                i cannot find the psp and c64 folder inside the roms folder
                                Juan Carlos Leal Payá 1 Reply Last reply Reply Quote 0
                                • Dwarf
                                  Dwarf last edited by Dwarf
                                  I wasn't able to configure psp controls, and dreamcast games don't work, i put the cd_boot.bin and dc_flash.bin files in the bios folder, is this it's place?
                                  Also, I was at 4.1 unstable and upgrade an our ago, now the rpi3 won't start, kernel panic.
                                  RPi3 Recalbox 7.0.1 (Stable)
                                    Juan Carlos Leal Payá @Juan Carlos Leal Payá last edited by
                                    @Juan-Carlos-Leal-Payá i created it and works very well 🙂
                                      Substring @Dwarf last edited by
                                      @Dwarf i had no problems updating
                                      Dwarf 1 Reply Last reply Reply Quote 0
                                      • Mercvtio
                                        Mercvtio last edited by
                                        I'm having trouble with Dreamcast games. They launch allright and run smoothly, but I can't save (not enough blocks, whatever the game) and whenever I hit the hotkey, Reicast crashes and sends me back to EmulationStation. Can anyone save ?
                                        I put the bios matching the OP md5 in the Bios folder, but it changes nothing.
                                        I'm a bit lost.
                                          voljega Banned @Mercvtio last edited by
                                          @Mercvtio reicast doesn't seem to be a retroarch nor libretro core so what you describe is perfectly normal
                                          Mercvtio 1 Reply Last reply Reply Quote 1
                                          • Mercvtio
                                            Mercvtio @voljega last edited by
                                            @voljega OK, so that's the normal behavior. Thanks !
                                            Any idea about my saving issue, anyone ?
