    Solved Recalbox 4.1 Retroarch HUD messages when playing games are displaying squares instead of letters
    recalbox 4.1 retroarch hud messages
    • kelv
      kelv last edited by
      Hello
      How are you?
      After upgrading to Recalbox 4.1 all in game Retroarch messages are displaying as squares. It seems like the locale is wrong ,as set in a non latin character language, for the messages, however I can get into retroarch and all the texts are in Latin characters.
      Please, Could anybody lend me a hand?
      THX so much, any help is appreciated.
      Kind Regards.
      Raspberry Pi model: RPi 3b+
      Recalbox build : 7.0.1 DragonBlaze
      Hardware: MicroSD UHS 128 GB up to 80 MB, Class 10 and 2.5 A Power Supply.
      Overclocked: 1485 MHZ
      Controller(s): Wired Xbox 360 PAD (working perfectly on any other game/emulator).
        Substring @kelv last edited by
        @kelv yeah we solved it on a from scratch installation, but not on an update
        kelv 1 Reply Last reply Reply Quote 0
        • kelv
          kelv @Substring last edited by
          @Substring THX for your reply. I think I will wait for the next compilation in order to check if it's fixed or not. I don't want to install it from the scratch, it's a bit pain to move all the roms and savegames etc. 🙂
            @kelv Use a USB key 😛 we've been recommending that for months 😉
            • kelv
              kelv last edited by
              As pointed by @Substring in other thread the following is fixing the issue 🙂
              •retroarch squares : there is a workaround : just remove ~/configs/retroarch/retroarchcustom.cfg Recalbox will regenerate it with the proper values. People using custom configfiles should add the value manually. Might be solved with a retroarch b*mp, no idea
