    My RPi won't boot up with Recalbox
    wont boot recalbox
    7751
    • loliver
      loliver last edited by
      So I decided to download recalbox for my raspberry pi and I did everything as instructed, downloaded, unzipped into my microsd and put it into my RPi, the thing is, when i put in the power, nothing happened, just a black screen. I do believe the Raspberry pi does have enough energy since I frequently use Kodi on it with it's power supply being from an extension. But the yellow light doesn't light up. I need help.
      • loliver
        Also, I'm using a Toshiba 64GB formatted MicroSD
          paradadf Staff last edited by
          It MUST be FAT32 formatted! Check the wiki!
          loliver 1 Reply Last reply Reply Quote 0
          • loliver
            loliver @paradadf last edited by
            @paradadf I have and I used Macronit Disk Partition expert to format my 64GB microsd into FAT32, I still put it into my RPi and it still has an empty black screen.
              voljega Banned @loliver last edited by
              @loliver partition type must be primary
                https://www.youtube.com/watch?v=hl59A3FTK-U&list=PL2oNQ0AT7fx2ExiSNrfHUzga5GnogI4sh&index=2
