    web interface not working
    web interface
    10011
    • webodan
      webodan last edited by
      Title says it all. I just can't get into the recalbox 4.0 web config (all my browsers on all my systems say connection refused every time even if i type in the IP and the recalbox is up and running and accepting connections over SSH). could someone toss me a hint on how to get it back up?
      Thanks in advance.
      • lackyluuk
        @webodan is the web manager disabled in your recalbox.conf?
        • Ratte
          Ratte last edited by
          I have the same problem here. config says that the manager is enabled. i can access the share-partition with the explorer and i am able to start the virtual gamepad at h11p://192.168.178.xx:8080/ , but there is no manager when i remove :8080 ?!?!
          using win10 netbook with ie11 recalbox 4.1 on rpi3, latest image "master-rpi3-build-9085147"
          what went wrong?
          •Raspberry Pi model: Pi ZeroW
          •Raspberry Pi model: Pi 3B @ 1350/500/500 MHz
          •Raspberry Pi model: Pi 3B+ @ 1550/500/500 MHz
          Substring Ratte 2 Replies Last reply Reply Quote 0
            Substring @Ratte last edited by Substring
            @Ratte why didn't you even think about saying you're not on 4.0 ?
            • Ratte
              Ratte @Ratte last edited by Ratte
              Ratte said in web interface not working:
              using .... recalbox 4.1 on rpi3, latest image "master-rpi3-build-9085147"
              @Substring:
              As much detailed as i can.
                @Ratte you're using an old build, it s been solved and even improved since grin
                Ratte 1 Reply Last reply Reply Quote 1
                  Substring @webodan last edited by
                  @webodan have you tried http://recalbox/ from Windows ?
                  webodan 1 Reply Last reply Reply Quote 0
                  • Ratte
                    Ratte @Substring last edited by
                    Thanks!
                    • webodan
                      webodan @Substring last edited by webodan
                      @Substring Hi, I ended up fixing this flaw by deleting the shutdown button files that I was editing to have shutdown functionality (they were /recalbox/scripts/rpi-pin56-power.py powerswitch.sh in that same directory and the switch script in /etc/init.d , then proceeded to write my own shutdown routine which is what i've been attempting today, since I wasn't happy with the speed of the shutdown nor the fact that I had to push it twice so that it would work. I remember that right after deleting the aforementioned files and commenting the power.switch line back the web interface would work again. It's odd I know but I didn't do any other change regarding the filesystem or the settings.
                      ... one thing that does not work though, is getting into it by using the hostname (in my case it is a different one) under Linux, I need to type in the IP of the Pi. Oh well whatever.
                      Substring Garu 2 Replies Last reply Reply Quote 0
                        @webodan linux uses avahi, so you shpuld append .local to the hostname
                        • Garu
                          Garu @webodan last edited by
                          @webodan I'm having the exact same issue for the exact same reason. And now I don't know what to do. 😞
