    Solved What is the name of the config file for PC Engine CD?
    Emulator Arcade/PC/Console
    name config file engine
    3220
    • gotogooch
      gotogooch last edited by
      I'm trying to assign a custom config for PC Engine CD games and I am unsure what the name of the default config file is for PC Engine CD games. I don't think it's the same for regular PC Engine games because I've got it working for that and the config I plan to use for CD is the same.
      I want to add a line in recalbox.conf to point it to my custom config but don't know what the original config file is called.
        Substring @gotogooch last edited by
        @gotogooch Simply run a PCECD game, and inside retroarch, use the Save as new config option. Find the file, point to it
        But i don't think there is anything special to PCECD
        gotogooch 1 Reply Last reply Reply Quote 0
        • gotogooch
          gotogooch @Substring last edited by
          @Substring Thank you for the reply. That is what I did for PC Engine (regular) and it works great, but has no effect on PC Engine CD 😕
          • gotogooch
            Hmm... Do I need to rename the new config for PCE CD to what I named the one for PCE (pcecustom.cfg)? I'll try that I tonight.
              Do you add In recalbox.conf : pcenginecd.configfile=/path/to/my/configfile.cfg ?
              • gotogooch
                gotogooch @acris last edited by
                @acris Not yet because I wasn't sure "pcenginecd.configfile" was the correct name. Can you confirm that will work?
                  paradadf Staff @gotogooch last edited by
                  @gotogooch yes. It is always the name of the system you want to configure.
                  • gotogooch
                    I got it. Thanks everyone!
