    How many PS3 controllers supported?
    many ps3 supported
    5511
    • arne
      arne last edited by
      Hi, I'm currently running recalbox with 2x ShanWan Ps3 controllers. Does recalbox support 3x and 4x PS3 controllers? Thanks.
      • lackyluuk
        @arne https://github.com/recalbox/recalbox-os/wiki/Compatibility-(EN)
        arne 1 Reply Last reply Reply Quote 0
        • arne
          arne @lackyluuk last edited by
          @lackyluuk Hi, Thanks I have read that information. Perhaps I was not clear. The ShanWan controllers work very well I know that from my experience. What I don't know is how many PS3 controllers can connect at the same time with Recalbox? 2? 3? 4? ??
          PS It was great to see in the Wiki that USB-PSx controller adapters will be supported in 4.1 beta, I can't wait 🙂
          tikiandskull Substring 2 Replies Last reply Reply Quote 0
          • tikiandskull
            tikiandskull @arne last edited by
            @arne the usb psx controller adapters work with recalbox 4.0 too!
            • arne
              arne @tikiandskull last edited by
              @tikiandskull Hi, Thanks but it did not work for me 😞 I connected my USB-PS Adaptor (Device Name: PS3/PC Gamepad, Product ID: 0x0523, Vendor ID: 0x2563, Manufacturer: ShanWan) to a PS1 Dualshock controller as a test with Recalbox 4.0.
              It did not work. Perhaps this particular adaptor is not supported? Any ideas?
              Thanks
              tikiandskull 1 Reply Last reply Reply Quote 0
                Substring @arne last edited by
                @arne i think they are already supported in USB in 4.0. Just set controllers.ps3.enabled=0 in recalbox.conf and it should do the trick
                • tikiandskull
                  @arne i just use this kind of adapter link text and it work out of the box
                  Substring arne 2 Replies Last reply Reply Quote 0
                    Substring @tikiandskull last edited by
                    @tikiandskull or use the gamecon driver 😉 it should support 2 PSX pads on 4.1
                    • tikiandskull
                      tikiandskull @Substring last edited by
                      @Substring Certainly, I just share my little experience on Recalbox... 🙂
                      • arne
                        @tikiandskull Thanks, I have ordered your suggested adaptor 🙂 Clearly my current adaptor is not yet supported. I will report back progress.
                        • tikiandskull
                          @arne Hope you are as lucky as I am!! 🙂
                          • arne
                            @tikiandskull Hi, I received the suggested USB-PSx adaptor today and I've tested it and it works OOB as you said. Thanks for your help 🙂
                            • tikiandskull
                              @arne you're welcome! 🙂
