    Solved Can't Connect
    cant connect
    11
    47
    29905
    • mazur
      mazur last edited by
      Hi,
      I just installed Recalbox 4.0.0 and i can't connect to network (cable and wifi).
      It give me IP, and i can access it from browser and windows network, can upload roms.. but can't use SCRAPER ou UPDATE.
      Looking at the logs, looks like it cant ping recalbox.com:
      --- recalbox.com ping statistics ---
      1 packets transmitted, 0 packets received, 100% packet loss
      PING recalbox.com (217.70.184.38): 56 data bytes
      I tried to ping it at windows and get same error, but i can ping www.recalbox.com
      Any idea what is hapenning? i tried many things, like making static IP.. same error
      Please look the screenshot:
      alt text
        How did your pi get 192.168.25.5 ?
        mazur 1 Reply Last reply Reply Quote 1
        • seic
          seic last edited by seic
          Have the same problem, others too on the german forums. Use 4.0 (Yolo Changelog) on a Pi2, I have access to shared and monitoring via Edimax Wlan Stick but have "no connection". It happens the last mh 4 Days? Before I had no Problems.
          • mazur
            mazur @Substring last edited by
            @Substring
            Thats the local IP (assigned by DHCP).. I think, maybe sobe ISP issue.. Still looking for a solution..
              Substring @mazur last edited by
              @mazur Do you have a DNS and a gateway set on your pi ? That's most probably an incomplete DHCP problem
              mazur 1 Reply Last reply Reply Quote 0
              • mazur
                @Substring Yes i tryed auto and static settings.. on PC i can't ping recalbox.com too.. maybe some router setting?
                  @mazur as i said : check your DNS and gateway on recalbox, and what happens on your router. If you set a static ip'on recalbox, you may have forgotten what i said
                  • mazur
                    Already check everything.. dunno what to do 😞
                      @mazur cdan you paste the result of ifconfig? and route or route print ?
                      • mazur
                        mazur @Substring last edited by Nachtgarm
                        @Substring , please check:
                        # ifconfig
                        eth0      Link encap:Ethernet  HWaddr B8:27:EB:79:9E:06
                                  inet addr:192.168.25.4  Bcast:192.168.25.255  Mask:255.255.255.0
                                  inet6 addr: fe80::ba27:ebff:fe79:9e06%1994427092/64 Scope:Link
                                  UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
                                  RX packets:158 errors:0 dropped:0 overruns:0 frame:0
                                  TX packets:163 errors:0 dropped:0 overruns:0 carrier:0
                                  collisions:0 txqueuelen:1000
                                  RX bytes:15499 (15.1 KiB)  TX bytes:24591 (24.0 KiB)
                        lo        Link encap:Local Loopback
                                  inet addr:127.0.0.1  Mask:255.0.0.0
                                  inet6 addr: ::1%1994427092/128 Scope:Host
                                  UP LOOPBACK RUNNING  MTU:65536  Metric:1
                                  RX packets:0 errors:0 dropped:0 overruns:0 frame:0
                                  TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
                                  collisions:0 txqueuelen:0
                                  RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
                        # route
                        Kernel IP routing table
                        Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
                        default         192.168.25.1    0.0.0.0         UG    0      0        0 eth0
                        192.168.25.0    *               255.255.255.0   U     0      0        0 eth0
                        # /etc/resolv.conf
                        search domain.name # eth0
                        nameserver 192.168.25.1 # eth0
                        # /etc/network/interfaces
                        auto lo
                        iface lo inet loopback
                        auto eth0
                        iface eth0 inet dhcp
                        auto wlan0
                        iface wlan0 inet dhcp
                        wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
                        # ping recalbox.com
                        75 packets transmitted, 0 packets received, 100% packet loss
                        I changed resolv.conf and interfaces but that files keeping returning to the default DHCP settings, already tryed to make them readonly, no sucess..
                          Have you tried pinging google rather ?
                          • mazur
                            @Substring Yes, pinging any other site works..
                              @mazur ok can you try a traceroute to recalbox.com, archive.recalbox.com and www.recalbox.com ? Thank you
                              CapFuture1975 1 Reply Last reply Reply Quote 0
                              • CapFuture1975
                                CapFuture1975 @Substring last edited by
                                When i use my pc with firefox, i also get a timeout error to connect to recalbox.com sever.
                                  recalbox.com itself means nothing, should try with www.recalbox.com. And as your are on the forum, i guess the DNS does work
                                  ooops it does work for me :
                                  # ping recalbox.com
                                  64 bytes from 217.70.184.38: seq=0 ttl=53 time=7.614 ms
                                  64 bytes from 217.70.184.38: seq=1 ttl=53 time=7.370 ms
                                  64 bytes from 217.70.184.38: seq=2 ttl=53 time=7.448 ms
                                  64 bytes from 217.70.184.38: seq=3 ttl=53 time=7.336 ms
                                  64 bytes from 217.70.184.38: seq=4 ttl=53 time=7.521 ms
                                  64 bytes from 217.70.184.38: seq=5 ttl=53 time=7.438 ms
                                  64 bytes from 217.70.184.38: seq=6 ttl=53 time=7.607 ms
                                  64 bytes from 217.70.184.38: seq=7 ttl=53 time=7.504 ms
                                  ^C
                                  8 packets transmitted, 8 packets received, 0% packet loss
                                  round-trip min/avg/max = 7.336/7.479/7.614 ms
                                    try pinging www.recalbox.com instead please
                                      Been searching : it pings recalbox.com to say if you're connected or not. I guess we'll change that in 4.1 as this DNS is not accurate and points to nothing special. So the message NOT CONNECTED is a mistake
                                      mazur DannyOcean 2 Replies Last reply Reply Quote 0
                                      • mazur
                                        @Substring Thanks very much!
                                        • DannyOcean
                                          DannyOcean @Substring last edited by
                                          @Substring
                                          Same problem.
                                          Network settings show "not connected".
                                          But connection via SSH is fine.
                                          Strange thing is that scraping of ROMs works and tracking with retroachievements server also work as it should. But no updates possible.
                                          Yes, w-lan settings are correct, also looked in the config.
                                          I can ping WWW.recalbox.com but not recalbox.com - same with firefox via laptop.
                                          recalbox pings recalbox.com to check if we're "connected".
                                          The "www" has to be in the address.
                                          So how do we update to 4.1 if we get no connection with 4.0?
                                            Substring @DannyOcean last edited by
                                            @DannyOcean easy pal ...
                                            4.1 is not here, we are taking care of that dns thing. We'd still have a few tricks up our sleeve anyway. I'd like to say it should be solved by the weekend as we're working on it, but it does not only depend on us
                                            DannyOcean 1 Reply Last reply Reply Quote 0
