    Solved How to play systems that require more buttons than your controller.
    GamePad/GPIO/USB encoder
    play systems require more buttons
    6
    8
    3330
    • Christopher 'Dange' Hornak
      Christopher 'Dange' Hornak last edited by
      Hey I have an 8 button SNES controler but what if I wanted to play a PSX game that requires the R2 and L2 buttons? OR if I wanted to play a N64 game.
      Is there a way to create key combinations that act as those other buttons? Like a extra buttons hotkey?
      Thanks!
      voljega 1 Reply Last reply Reply Quote -1
        voljega Banned @Christopher 'Dange' Hornak last edited by
        @Christopher-'Dange'-Hornak off course not there's no way to do that
        Christopher 'Dange' Hornak 1 Reply Last reply Reply Quote 0
          Christopher 'Dange' Hornak @voljega last edited by Christopher 'Dange' Hornak
          @voljega seems like something that could be possible with button combinations. Like if if I press Y and B together it could act as R2.
            paradadf Staff last edited by
            Who does that? Please, just get a proper controller! Nobody tries to play SNES with a NES pad!
              @Christopher-'Dange'-Hornak and how could you then press the same two buttons at once in a standard game ? (Sf2 on snes for example)
              Anyway games aren't designed to be played like that and it's really a bad idea, esoecially given the low cost of controllers
              • Anonpebbles
                Anonpebbles last edited by
                The only fix I have found for this is by following this guide exactly http://bfy.tw/8xYV
                  You can't, that's all. And there won't be any investigation on making pointless developments for some probably impossible key combos in various emulators
                  • DannyOcean
                    DannyOcean last edited by
                    Just use a PS3 Controller. Sixasis or Dualshock 3 work like a charm.
                    101.4k
