    Recalbox reset itself to default, all settings and roms gone?
    recalbox reset itself default settings
    9
    26
    17599
    • hobbitlap
      hobbitlap last edited by
      i know the is pretty old topic, but i got the same issue twice with different sd card and pi 3b.
      habe you found the issue ?
      i am on 4.1 beta !!
        OyyoDams Staff @hobbitlap last edited by
        @hobbitlap Hi,
        First of all why don't you install the latest stable version ? I'm not sure you'll get support for the outdated beta version.
        • ChickenW
          ChickenW last edited by
          I'm running into the same exact problem.
          with the last release (4.1.0).
          each time i restart my Pi, all settings are back to default (except for the overscan param) and all the roms vanish from the storage.
          Plus when i add roms, they don't appear in the liste, and there is no more "update game liste" button available anywhere in the menu. 😢
          BlingTyson 1 Reply Last reply Reply Quote 0
          • BlingTyson
            BlingTyson @ChickenW last edited by
            @chickenw said in Recalbox reset itself to default, all settings and roms gone?:
            Same Issue with a fresh install trough NOOBS on a new Pi3... Any help ?
            • Javier Sandoval
              Javier Sandoval last edited by
              i notice i had the same issue once but on pcx64, on the options for the share drive, just change it once to something ealse, reboot, then change it once again to internal and reboot, problem gone.
              • jamalwsilva
                jamalwsilva last edited by jamalwsilva
                Fixed with "fsck /dev/mmcblk0p2".
                Change mmcblk0p2 to your actual userdata partition. And use it with care... Some data may be lost.
                100.2k
