    Psp issue on recalbox 4.1 alpha xu4
    Emulator Arcade/PC/Console
    psp issue recalbox 4.1 alpha
    7170
    • Mxg848
      Mxg848 last edited by
      Hi I can't play any games on the Psp on recalbox 4.1. IT Maybe something I am doing wrong. The only thing I've done is drop the iso in the rom/Psp folder. Is it something I'm doing or does it just need more work. I know this version is in alpha so I'm not sure if it's working or not
        voljega Banned @Mxg848 last edited by
        @Mxg848 4.1 is not supported officially yet.
        However maybe you just need the bios ? Look into readme.txt to see if it's not mentionned
        • Mxg848
          Mxg848 last edited by Mxg848
          I checked all it says is place your iso, bin, img, cue in this directory. nothing about bios
            Hello
            make an issue in https://github.com/recalbox/recalbox-os/issues/998
            Mxg848 1 Reply Last reply Reply Quote 0
              Substring @Mxg848 last edited by
              @Mxg848 what does "can't play" mean ? The emulator doesn't launch ? The pad doesn't respond ?
              @voljega PPSSPP doesn't need any bios
              • Mxg848
                When I click on a game it goes to a black screen then right back to the Psp game list
                grgohr 1 Reply Last reply Reply Quote 0
                • Mxg848
                  Mxg848 @acris last edited by
                  @acris I will just wanted to make sure I wasn't doing something wrong before I did
                    @Mxg848 how sure are you that the game works ? Tried it on ppsspp on your computer ?
                    • Mxg848
                      Yes I tried one of them Kingdom Hearts but not the others
                        @Mxg848 i've tried KoH too, had no issue (on pi3 at least). Will eventually check on xu4
                        • grgohr
                          grgohr @Mxg848 last edited by
                          @Mxg848 I had the same problem with the last XU4 build : the PPSSPPSDL bin does not work
                          take the one from the last RPI builds (inside /usr/bin/) and replace it, it will solve the issue
                          • Mxg848
                            thanks ill try that when i get off work
                            • Mxg848
                              Mxg848 @Substring last edited by
                              @Substring thanks
                              • grgohr
                                grgohr @grgohr last edited by acris
                                @grgohr said in Psp issue on recalbox 4.1 alpha xu4:
                                sorry not from last rpi build, it has same issue, they both raise
                                File "/usr/lib/python2.7/subprocess.py", line 1335, in _execute_child
                                raise child_exception
                                OSError: [Errno 13] Permission denied
                                take an older bin from previous xu4 builds, the one from early november works fine:
                                xxx delete link
                                (PPSSPPSDL should be ~10MB instead of ~6MB)
                                • Mxg848
                                  i have build 4.1/alpha from oct 8 what build from November? also i new at all this so what do i do exactly?
                                  101.4k
