    PSX roms showing multiple same titles
    6
    21
    14315
    • eb2016
      eb2016 last edited by
      Hi.
      I've been testing out some of my PSX roms in Recalbox. Most roms have a .bin file and .cue file in the roms folder and the roms work fine.
      The issue is when I go to a rom i.e Tekken 2, when i click on the game title it'll open up another screen and list the game title multiple times. I think it's looking at the files in the roms folder as multiples of the same game when it's actually just seperate games that make the rom work. Does anyone know if there's a work around for this?
      I've attached a pic to show you what's happening
        paradadf Staff last edited by
        https://github.com/recalbox/recalbox-os/issues/290
        eb2016 1 Reply Last reply Reply Quote 0
        • eb2016
          eb2016 @paradadf last edited by
          @paradadf
          Cheers. had a look at that thread and the link mentioned doesn't work.
          https://github.com/digitalLumberjack/recalbox-buildroot/blob/recalbox/board/recalbox/fsoverlay/root/.emulationstation/es_systems.cfg#L135
          Also saw the part where it says it's been fixed 4.1 however I'm using 4.0 as 4.1 hasn't gone public yet has it?
            voljega Banned @eb2016 last edited by
            @eb2016 edit the es_systems.cfg file and remove .bin and .BIN from the psx file types
            • eb2016
              eb2016 @voljega last edited by
              @voljega where do I find that file? I searched for it on my flashdrive and it isn't coming up.
              Nachtgarm seic 2 Replies Last reply Reply Quote 0
              • Nachtgarm
                Nachtgarm @eb2016 last edited by
                @eb2016 Read the wiki. 😉
                • seic
                  seic @eb2016 last edited by
                  @eb2016
                  Convert your games to .pbp via psxpsp. Makes the games smaller, and you have just one file per game.
                  • eb2016
                    eb2016 @seic last edited by
                    @seic said in PSX roms showing multiple same titles:
                    psxpsp
                    Cheers. I managed to get the original issues solved. However, how reliable is PSXPSP?
                    seic 1 Reply Last reply Reply Quote 0
                    • seic
                      @eb2016
                      I converted all of my psx games to .pbp with PSX2PSP for the Pi and had no problems if the "core" material had none.
                      • eb2016
                        @eb2016
                        Are you running your PSX games through Recalbox?
                        • seic
                          seic @eb2016 last edited by seic
                          @eb2016
                          Yes (rpi2) via the default psx emulator pcsx rearmed. He has no problems with .PBP . I run these games also on my Nvidia Shield TV which uses the android RetroaAch with the same pcsx rearmed core and there also no problems. PSX Mednafen Core I haven't tested so far.
                          eb2016 2 Replies Last reply Reply Quote 0
                          • eb2016
                            @seic
                            Awesome! I'll give it a try this week and see how it goes. Thanks heaps for all your info on this!
                              Substring @eb2016 last edited by
                              @eb2016 we removed the display of .bin files in 4.1. that's all
                              • eb2016
                                eb2016 @Substring last edited by
                                @Substring 4.1 is still a while away from public release though?
                                Substring 1 Reply Last reply Reply Quote 1
                                  @eb2016 4.0 is stable, so 4.1 will sooner or later be released as unstable for kamikazes, then hit the first beta stage once we feel it looks ok for masssive testings
                                  • eb2016
                                    @seic Had a play around with PSX2PSP. Works great! the files played fine on RecalBox.
                                    One question, when you export your file, is there a setting where it'll automatically change the file name to be the the game name? i.e crashbandicoot.PBP instead of just EBOOT.PBP?
                                    • seic
                                      @eb2016
                                      Sadly no. This tool is mainly for the PSP which uses the Eboots in named folders. You have to rename the Eboots manually.
                                      • eb2016
                                        @seic I thought that might be the case. All good though as it exports the folder titles nicely so I'll just do the old cut n paste.
                                        • eb2016
                                          @seic I gave PSX2PSP a go and it worked! Just wondering for multi disk games like Final Fantasy 7, is it best to combine all the separate disks into the one PBP file? I made them into 3 separate files for Final Fantasy (i.e disk1.PBP, disk2.php) But if I combine all the disks into the one file, will it run properly, be able to switch between disks and read save/memory card data properly? or should I keep each disk in its own separate file?
                                          • seic
                                            @eb2016
                                            I don't know if it works if you separate them all. I combined all of my Multi Disc Games to one file and had no problems so far.
