    I can not transfer the games on USB key
    GamePad/GPIO/USB encoder
    transfer usb key
    11939
    • Manuel Giuseppe Trizzo
      Manuel Giuseppe Trizzo last edited by
      can know the exact procedure to enter rom on USB key?
      What format should have?
      • lackyluuk
        @Manuel-Giuseppe-Trizzo here you go: https://github.com/recalbox/recalbox-os/wiki/Use-an-external-usb-storage-device-on-recalbox-(EN)
        Manuel Giuseppe Trizzo 1 Reply Last reply Reply Quote 0
          Manuel Giuseppe Trizzo @lackyluuk last edited by
          @lackyluuk Recalbox Does not recognize my USB key
            Substring @Manuel Giuseppe Trizzo last edited by
            @Manuel-Giuseppe-Trizzo single partition, fat32 is the best
              -Format In fat 32
              • Insert the key in recalbox, and I log
                -Settings System, and does not make me choose USB key
                paradadf Staff @Manuel Giuseppe Trizzo last edited by
                @Manuel-Giuseppe-Trizzo Are you a 100% sure it is properly formatted to FAT32? Sorry to ask, but it happens all the time!
                Is it a USB-Stick or a harddrive? Are you connecting it directly to the Raspberry or over a USB-Hub?
                  Manuel Giuseppe Trizzo @paradadf last edited by
                  @paradadf Format with Windows 10, is a verbaim 32 gb pen drive USB 2.0, connecting it directly to the Raspberry !!
                    paradadf Staff @Manuel Giuseppe Trizzo last edited by paradadf
                    @Manuel-Giuseppe-Trizzo i have an USB-Stick that gets only NTFS formatted through Windows and need to use other tools to get it FAT32 formatted.
                    Can you try with other stick? I'm just trying to narrow the root of the problem down.
                      @paradadf
                      I tried with another 4GB button is working,to me it serves key 32 gb.
                      I can formatare with some program in fat32?
                        @Manuel-Giuseppe-Trizzo I'm not sure that I understood what you wrote. But you can format anything to FAT32 with this software:
                        http://www.ridgecrop.demon.co.uk/index.htm?guiformat.htm
                        Manuel Giuseppe Trizzo 1 Reply Last reply Reply Quote 1
                          @paradadf
                          thanks for the link
                          I formatted but does not operate the USB key
                            @Manuel-Giuseppe-Trizzo if other USB-Sticks you try work and there is just one that won't work, then somehow it must be faulty. I don't know what else to say.
                              Manuel Giuseppe Trizzo @paradadf last edited by Manuel Giuseppe Trizzo
                              alt text
                              very strange
                              DISK USAGE: 3GB/11 GB (SD 16 GB)
                              STORAGE DEVICE: RETROUSB (Name key usb 32GB)
                                paradadf Staff last edited by
                                I believe you are not formatting it right :S
                                  @paradadf
                                  Format in this way
                                  alt text
                                    @Manuel-Giuseppe-Trizzo as I said before, your stick might be faulty. No idea. If you format it right and it doesn't work, but others do, then what else?
                                      Buy SD 32-64 GB?
                                        I cannot answer you that. It depends on what you want to emulate and the size of the collections you want to have. CD based consoles need more storage.
                                          Thanks so much
                                          How do I save in the game?The manual indicates hotkey +Y.
                                          I can not find the button Hotkey
                                            You need to configure a button (for example L3 or select) as a HK before being able to use it.
