    GPIO rotary volume
    GamePad/GPIO/USB encoder
    gpio rotary volume
    6
    74
    36141
    • dh04000
      dh04000 @Substring last edited by
      @Substring Oh, that seems simple. Thank you. 🙂
      I'l try it sometime this week/weekend and report how it went.
        Substring @dh04000 last edited by
        @dh04000 yeah we made it simple.for users with minimum bash knowledge to add a custom startup script, hence the custom.sh in the home folder
        • dh04000
          @Substring @acris
          Complete success! The script starts up with the system now! Thanks for the help!
            @dh04000
            good news , may be to make a complete tutorial 😄 ? please
            dh04000 1 Reply Last reply Reply Quote 0
            • dh04000
              dh04000 @acris last edited by
              @acris
              Ok. What form should it be in? A google document, typed into this forum thread, a new forum thread, something else?
              Also, how do I do those cool code windows?
              • lackyluuk
                @dh04000 @acris the articld could be written directly in the wiki?
                https://github.com/recalbox/recalbox-os/wiki/Mini-How-To-(EN)
                  In the wiki 😄
                  • dh04000
                    dh04000 @acris last edited by dh04000
                    @acris I'm still interested in writing a how-to use this script, but I don't know how to write to the wiki. Can I just send someone a google document with the how-to in it?
                    EDIT: Also @Substring once I wrote the how-to, would you mind checking it with your system since you also have a rotary encoder?
                      No problem make google docs and a modo add your document on wiki.
                        @dh04000 mine is not plugged hahaha
                        the wiki syntax is farily simple, you even have a WYSIWYG bar to edit
                        • dh04000
                          dh04000 last edited by dh04000
                          Done: https://docs.google.com/document/d/15gvyNhxF_knimoVxYE0X3E4Fe1n_DSU06Wli_QtnwxE/pub
                          @Substring @acris @lackyluuk It needs some minor editing work for the wiki. I put comments in blue on what needs to be done.
                          • dh04000
                            I started editing the wiki, but I'm not good at it.... Also, please test those copy/paste instructions. I haven't had a chance to try it on my machine yet.
                            • dh04000
                              https://github.com/recalbox/recalbox-os/wiki/Rotary-Encoder-via-GPIO-(EN)
                                Great !!! thanks a lot @dh04000
                                • dh04000
                                  @acris It's not done. I don't know how to add the text box with the script. Also, I want to show how to increase the rate of volume change, and change min and max of the script in the tweaks section. Which I still have to write. Got to test it on my machine first. Also, I need someone to test my instructions and verify that it works as intended.
                                    @dh04000 you add code in 2 ways (wirks the same on the forum :
                                    • either as a "span" lile this between back quotes
                                    • either as a block
                                    Like this
                                    Between a pair of triple back quotes. But beware, you must start a new line after each triplet of back quotes. So my block above looks like :
                                    3 back quotes without spaces
                                    Like this
                                    Please note that on github you can specify which language is used in a code block. You just need to add the language name right after the opening triplet, say :
                                    3 back quotes python
                                    Like this
                                    3 back quotes
                                    The wiki langiage nme is known as markdown, and github has an advanced markdown for code
                                    • dh04000
                                      dh04000 last edited by acris
                                      @Substring
                                      I'm trying to do this --> http://imgur.com/a/C7zRl
                                      Edit modo :
                                      test
                                      test
                                        @dh04000 Added the python code. You can't do as in the source because it's a gist using several files
                                        • dh04000
                                          @Substring
                                          Thank you! Now all I have to do is to point out, in the Tweaks section, how to change the gpio, volume increments, and volume range in the script, and the guide is complete. 🙂
                                            @dh04000 Thank you very much for your contribution 🙂
                                            100.2k
