    gpio tft screen
    GamePad/GPIO/USB encoder
    gpio tft
    5655
    • aaroncastello123
      aaroncastello123 last edited by
      Hello! I'm having some issues with a tft touchscreen
      http://www.banggood.com/3_5-Inch-320-X-480-TFT-LCD-Display-Touch-Board-For-Raspberry-Pi-2-Model-B-RPI-B-p-1023432.html
      I have some questions about this tft screen:
      Can I use it with a pi3? how can I configurated this lcd? how i should configurate it?
      Has anyone can help me? Thanks for all
        well, the tft screen master is @ian57 or maybe @cluf20
        the only help i can point you at is https://github.com/recalbox/recalbox-os/issues/915
        • cluf20
          cluf20 last edited by cluf20
          Hello,
          I think this tft screen should work but I can't guarantee you.
          aaroncastello123 1 Reply Last reply Reply Quote 0
          • aaroncastello123
            aaroncastello123 @cluf20 last edited by
            @cluf20 what I should do to play with this screen? help me please 🙂
              There is a wiki on the go by @ian57 + the issue i mentionned already gives a few tips
              • ian57
                ian57 Staff @Substring last edited by
                @subs @aaroncastello123 @cluf20 This 3.5 screen works but you will not ba able to get the right fps with it. Its resolution is to high for the SPI bus badwidth and you'll get at max 20fps in game
                chose a 320x240 SPI tft display or the Geekwrom HD 3.5 Inch TFT Display Shield 800x480 For Raspberry Pi 3B 2B With 2 Keys And Remote IR http://www.banggood.com/Geekwrom-HD-3_5-Inch-TFT-Display-Shield-800x480-For-Raspberry-Pi-3B-2B-With-2-Keys-And-Remote-IR-p-1069730.html in DPI mode. see my post here https://forum.recalbox.com/topic/4129/buy-dpi-display-in-recalstor/9
                • aaroncastello123
                  thanks for all!! i'll buy this one 🙂
