    No sound over HDMI. (Only Audio-Jack works)
    sound hdmi audio-jack
    5803
    • farbkasten
      farbkasten last edited by
      Hello,
      after a few weeks i started my Recalbox-System again and now the sound over HDMI doesn`t work.
      Only the sound over Audio-Jack works.
      My TV is the same.
      Thats annoying because i had to plug external speakers to my rpi2 everytime.
      Could someone please help me to fix my problem.
      thx
        Hello
        try an another cable.
        check in emulationstation > sound options > output sound > auto or hdmi
        farbkasten 1 Reply Last reply Reply Quote 0
        • farbkasten
          farbkasten @acris last edited by
          @acris It's the same cable with that recalbox already worked.
          I tryed both options but no change.
          • farbkasten
            farbkasten @farbkasten last edited by
            @farbkasten I've found a forum post about maybe the same problem.
            https://forum.recalbox.com/topic/2269/no-sound-via-hdmi-on-4-0-beta-1
            • farbkasten
              @farbkasten no solution?
                unless you modified the c**nfig.txt, it should work. Ar maybe the volum is set to 0 ?
                • farbkasten
                  farbkasten @Substring last edited by
                  @subs volume is up because with audio-jack it works.
                  I changed nothing that had to do with audio in the config.
                  what about the other thread ? - https://forum.recalbox.com/topic/2269/no-sound-via-hdmi-on-4-0-beta-1
                  • farbkasten
                    @farbkasten still no solution?
                      can you run /recalbox/scripts/recalbo-support.sh, upload the archive and give me the link please ?
                      • dorian man
                        dorian man last edited by dorian man
                        This post is deleted!
