    No sound via HDMI on 4.0 Beta 1
    sound hdmi 4.0 beta
    8
    9
    9324
    • snipah
      snipah last edited by
      Could anyone help me with my problem, that I do not have any sound on V4.0 Beta 1, while sound is fine with V3.3.0? System Volume is always zero and if i raise the volume, it has no effect and is not saved. In recalbox.conf everything looks fine. Even several fresh installs (also including unstable build) did not help. I use a Raspberry Pi 2. So obviously hardware is fine, because everything works in V3.3.0. What is wrong? Obviously no one else had this problem?!
      • toz-info
        toz-info last edited by
        hi, i am also lost alone with this sound. i think i remember it was working in 3.x, now i made a new sd-card for my raspberry with 4.0beta it is not working anymore. and shows exactly the same behaviour as you described. hmmmm.....waiting for more beta?....
        • esmith13
          esmith13 last edited by
          Did you try setting audio mode to HDMI instead of AUTO in the ES menu? I have one TV that won't work on AUTO and I must force audio over HDMI to get sound.     Eric
          My Raspberry Pi's:
          Pi A, Pi B, (2) Pi B+, (2) Pi 3
          Currently looking for a reason to buy a Pi Zero or two ;-)
          • kazter
            kazter last edited by
            The same is here. Tried your workaround with the HDMI audio mode, but no change at all. Something wierd is that the system volume bar is set to 0%. When I change it to any other number and confirm, then it does not change when I enter the audio settings again. But in the Recalbox manager it was accepted... seems it was not actualized..  Besides, audio in Version 3 of Recalbox works great. I am using the latest beta version till now. Hope this will be fixed soon. Cant play Tetris without sound!! 😉
            • sulsa
              sulsa last edited by
              Same problem. Ever find a solution?
              • sulsa
                Just wanted to add that sound works fine in kodi, just not in retropie.
                • Pdagarcia
                  Pdagarcia last edited by Pdagarcia
                  I got the same problem
                  Has anyone resolved this problem? 😕
                  I'm using 4.0 beta 5
                    Substring @Pdagarcia last edited by
                    @Pedro-Garcia please start your own topic
                    • Ghiligan
                      Ghiligan last edited by
                      I realize this post is old but I ran in to this same issue on a much newer verison of recalbox and this thread was first when searching "how to get sound to work on recalbox". I thought I'd post what I did to fix my issue to help other fellows.
                      I have speakers in my monitor that Raspberry Pi only recognizes when the connected monitor is turned on BEFORE the Pi is turned on. Once this is done, go to main menu > sound settings, and make sure your settings are to your preferences. Note: I don't use auto for the output device (the auto setting has created problems for other users in the past).
                      So if hardware is not working at all with your Raspberry Pi, trying connecting it to the Pi, turn on said hardward, then turn on your Pi.
