    Solved Remote control in Kodi does not work
    MediaCenter & Dualboot
    remote control kodi not working
    • lackyluuk
      lackyluuk Translator last edited by Nachtgarm
      Hello 🙂
      I just setup a remote control according this manual: https://github.com/recalbox/recalbox-os/wiki/Infra-red-remote-control-on-the-Recalbox-(EN)
      It worked and with the command "irw" I can see what I have pressed.
      BUT, if I open Kodi, nothing happens. I can press what I want, but there is no feedback in Kodi.
      SOLUTION: If you rename your remote control, be sure that you rename it also in the Lircmap.xml 🙂
      • Nachtgarm
        Nachtgarm last edited by
        Please use the Topic Tools to mark a thread as solved
