    Hay alguna manera de usar mandos bluetooth IPEGA, en concreto el IPEGA 9028?
    Mandos/GPIO/Codificador USB
    hay alguna manera usar mandos
    6
    37
    21338
      paradadf Staff @urtzai last edited by paradadf
      @urtzai si, dejalo con tres espacios. No se que mas decirte, por eso pregunto los que saben!
      @acris any idea what to do?
      support files:
      https://mega.nz/#!dNxhnYyQ!IkffYVBB9VDv4oPPLvC5CJlafUTw9iyLKS7Obbq9GcI
      my instructions were:
      mount -o remount, rw /
      echo 'SUBSYSTEM=="input", ATTRS{name}=="ipega Bluetooth Gamepad   ", MODE="0666", ENV{ID_INPUT_JOYSTICK}="1"' >> /etc/udev/rules.d/99-joysticks-exotics.rules
      reboot && logout
        Hola @urtzai and @paradadf
        I think you need to edit recalbox.conf
        global.inputdriver=sdl2
        save and reboot
          paradadf Staff @acris last edited by
          @acris gracias!
          Entendiste @urtzai? Cambia ese parametro en recalbox.conf, reinicia y volve a intentar.
          • urtzai
            @acris Yes, I did but no luck... Still cannot configure my gamepad...
            Do you need more feedback files? I wonder, do I have to do this configuration everytime I update my system?
            Gracias @paradadf y @acris
              @urtzai if it works, the rule will be added to recalbox by default and it will work out of the box in the future.
              • urtzai
                Ok! Perfect! So what else can I do to help you? @acris
                • urtzai
                  Hi, any idea of how can I fix this? @acris @paradadf
                  Thank you
                    Hello @urtzai
                    how can I fix this
                    fix what ? your gamepad works now ?
                    • urtzai
                      @acris No it doesn't... What else can I do to configure my gamepad? Do you know any other workaround?
                        Go go emulationstation menu options gamepad.
                        @paradadf I dont understand the problem
                          paradadf Staff @acris last edited by paradadf
                          @acris I asked him (after looking at his support files) to try this:
                          reboot && logout
                          After that, you told him to change the sdl2 on recalbox.conf, but that didn't work for him either. He can pair the controller, but he can't configure any button.
                            @urtzai I just found something else to try for your ipega 9025 here:
                            https://forum.recalbox.com/topic/2934/ipega-9021-dont-work/2
                            (I have no idea if editing the bluetoothcontroller script helps)
                            You NEED the global.inputdriver=sdl2 in recalbox.conf
                            Encende el mando manteniendo presionado primero X y luego (sin soltar X) presiona Home.
                            • urtzai
                              Finally working!! This is what I did:
                              Make file system writeable:
                              Edit recalbox.conf:
                              Edit bluetoothcontrollers.sh. Delete this lines:
                              killall bluetoothd
                              bluetoothd -u
                              Replace with:
                              bluetoothd -u
                              sleep 5
                              killall bluetoothd
                              Reboot the system:
                              reboot && logout
                              Pair the gamepad with X+HOME buttons and configure it.
                              Thank you @acris and @paradadf!! Hope this will help for future improvements!!
                              jonq 1 Reply Last reply Reply Quote 0
                                I forgot this information with bluetoothm
                                Thanks.
                                Your gamepad add in the next version.
                                • jonq
                                  jonq @urtzai last edited by jonq
                                  @urtzai He hecho lo que comentas, lo encuentra y empareja pero a la hora de configurarlo no esta disponible. Solo sale el mando USB.
                                  • LeSoquiaque
                                    LeSoquiaque last edited by
                                    Buen dia.
                                    Hice todo lo que indica y la unica forma de que pueda configurar el control es si lo vinculo en modo teclado. Dentro de la interfaz funciona perfecto pero cuando entro a algun juego no lo reconoce. ¿algo que este omitiendo para que pueda utilizarlo en los juegos?
                                    Mi control es un ipega 9055
                                    Gracias
                                      paradadf Staff @LeSoquiaque last edited by
                                      @LeSoquiaque no podes utilizar cualquier modo, peor aun el modo teclado. Tenes que usar el modo de gamepad, sea cual sea. Y por favor, abre tu propio hilo porque tenes un mando de distinto modelo. Podes hacer referencia a este y aportar todos los archivos de soporte que han sido pedidos aqui, si deseas recibir ayuda. Gracias.
                                      100.6k
