    Manual metadata disappears when games lists updated?
    metadata disappears lists updated
    5746
    • Matt Bauler
      Matt Bauler last edited by
      I decided to manually enter metadata for a few games that wouldn't scrape like Pac-Man, NBA Jam, F-Zero, etc...got it all good for one system with pics and info I manually entered from thegamedb and it stayed there until I did a games list update, then it disappeared, but it kept the custom names I entered (basically removing the region/revision), so I'm confused why it would keep that and discard everything else?
      Anybody know why or how to avoid this?
        paradadf Staff last edited by
        What does it mean "I did a gamelist update?" Or better, how did you you it?
        • Nachtgarm
          Nachtgarm last edited by
          I think he means "Game Settings -> "Refresh Game list" in ES.
          I don't know how to avoid this problem but you should report i on GitHub and for the future I recommend using the Universal XML Scraper by Screech. It finds ALL games, is faster and the results are waaay better, than the TheGamesDB results πŸ™‚
          • Matt Bauler
            Matt Bauler last edited by Matt Bauler
            @Nachtgarm said in Manual metadata disappears when games lists updated?:
            I took your suggestion to use Universal XML Scraper but I'm getting quite a few mismatches with images and games. I tried changing the api order but that only seems to make it worse. Any suggestions?
            I'll add that the games are all verified against no-intro dat files. I am fine going through and manually fixing games, but I don't know how to get my own image to replace the incorrect one for the mixed artwork.
            • screech
              screech last edited by
              Hi @Matt-Bauler
              Can you tell me an exemple of mismatch and your configuration ?
              I'll check what's going wrong πŸ˜‰
              For info, Universal XML Scraper 2 is comming πŸ˜‰ (Like winter πŸ˜› )
              Matt Bauler 1 Reply Last reply Reply Quote 0
                paradadf Staff @Matt Bauler last edited by
                @Matt-Bauler you can always enter the database and see what's going on.
                https://forum.recalbox.com/topic/3842/how-to-screenscraper
                  Substring @Matt Bauler last edited by
                  @Matt-Bauler How did you do your edits ? through recalbox ? editing yourself gamelist.xml ? If you edited the xml, you MUST turn off ES, otherwise your data will be wiped
                  Ex dev - Merci de me rΓ©pondre en utilisant @substring pour que je sois notifΓ©
                  • Matt Bauler
                    Matt Bauler @screech last edited by Matt Bauler
                    @screech said in Manual metadata disappears when games lists updated?:
                    Hi @Matt-Bauler
                    Just started out in NES games as a test and about 80% were correct. Some examples:
                    Addams Family, The (USA) = Baseball Sumulator 1.000
                    Advanced Dungeons & Dragons - DragonStrike (USA) = Karnov
                    Advanced Dungeons & Dragons - Heroes of the Lance (USA) = Kid Kool
                    Adventures of Lolo 2 (USA) = The Krion Conquest
                    Adventures of Lolo 3 (USA) = Krusty's Fun House.
                    Checked the database:
                    Adventures of Lolo 2 (USA).nes
                    CRC: 862AB1E5
                    Checked the game it was scraping instead and the CRC didn't match or anything...no sign of that I can see of why it would pull Thr Krion Conquest instead...
                    exactly what it expected in the database but scraped a completely different game? I used the default settings and the roms are all verified against no-intro's dat files. I even tried different reorderings of how it scrapes in the advanced settings and that just made it worse.
                    Also, how do I get the new xmls to stick in the system exactly once they are scraped with the program? I know you need root access and to stop emulationstation or something but don't know the exact way...
                    Copyright Β© 2021 recalbox.com
