    Solved Someone have the 8bitdo NES30 Pro in bluetooth working ?
    GamePad/GPIO/USB encoder
    someone 8bitdo nes30 bluetooth
    9130
    • OZRay
      OZRay last edited by
      Hi, I recently build my mini Recalbox on a Rasberry Pi 3 and I bought 2 NES30 Pro controller.
      They are working out of the box when connected USB, no setup to do and working great.
      The best setup would be to make it work Bluetooth but after many many hours they still don't pairs.
      The new version came with firmware 1.7 I also tried with 1.62 1.68 1.69 and none are working...
      controllers.bluetooth.enabled=1 and all the other controller setting are at 0.
      I'm desperately looking for someone that figure out how to make NES30 Pro working in Bluetooth.
      Regards,
        paradadf Staff @OZRay last edited by paradadf
        @OZRay are you trying to use the internal bluetooth from the RPi3? It isn't supported yet! You need a bluetooth dongle for the moment.
        • OZRay
          OMG really! ๐Ÿ˜ž That's why many are talking about Bluetooth dongle... ๐Ÿ™‚
          Do you know what is the best compatible dongle to use for the NES30 Pro ?
          Can it be connected directly in one of the 4 USB port? I also read that some
          dongle need to be connected to a powered USB hub???
          Thanks for your help!
          • lackyluuk
            There is a very helpful wiki .
            https://github.com/recalbox/recalbox-os/wiki/Compatibility-(EN)
            Give it a try ๐Ÿ™‚
            Dongles actually do not need a separate power supply.
            • OZRay
              Sorry found it just after posting my message thanks for your help I will order one.
              You know if the internal one will work soon ?
                Don't expect the internal BT ni 4.0, but rather 4.1
                And don't ask for an ETA for 4.1 ๐Ÿ˜„ The ETA is "When it's done"
                On recalbox.com there is a suggested amazon basket. Despite it points to the french amazon, you can still get the dongle references. It's a CSL one
                Ex dev - Merci de me rรฉpondre en utilisant @substring pour que je sois notifรฉ
                • OZRay
                  Hahaha yes no problem will go get a dongle, just don't wanted to go get a dongle if everyone except me know that internal BT will be supported this week, ๐Ÿ˜›
                  Thanks
                  Copyright ยฉ 2021 recalbox.com
