    N64 games runs slow
    Emulator Arcade/PC/Console
    nintendo64 slow settings raspi3
    6
    10
    5274
    • Alberto.Kutran
      Alberto.Kutran last edited by
      Hi, at opening a N64 game, it runs slow, about 1/3 its real speed. My gear is this:
      Raspberry Pi 3 model B
      Recalbox 9.1
      Micro SDXC U1 Class 10
      I've tested Mario Kart 64 and Star Wars Episode 1: Racer, in every available emulator, having similar results.
      I want to know if there's some settings configuration to play the games at its original speed, or if is a hardware issue (although according of the Wiki entries, it could run)
      Sorry for my not-so-good English, I'm Chilean xD
      Greetings, and thank you in advance
      • airdream
        airdream Theme moderator @Alberto.Kutran last edited by
        @Alberto-Kutran
        did you tried different "cores"?
        maybe the default one is not ideal for these two games
        Alberto.Kutran 1 Reply Last reply Reply Quote 0
        • Alberto.Kutran
          Alberto.Kutran @airdream last edited by
          @airdream yes, I've tried all emulators and cores for N64. and the ones which run the games, they run slow 😞
          • airdream
            This guy have tested Super Mario Kart 64 with recalbox 9.1 on a RPI3B+ without any problems
            https://youtu.be/1zFK8G-kXgU
            Is you power AC adapter is powerful enough?
            Do you have some heating problems?
            Or maybe your roms is the problem
            • Alberto.Kutran
              Alberto.Kutran @airdream last edited by Alberto.Kutran
              @airdream I've checked the video, and he has a Raspi3+, and I have a Raspi3, however I tried overclocking at maximum (1350 MHz vs 1450 MHz of the guy of the video) and Mario Kart improved its performance at almost full speed, but Star Wars Racer still slow. Sadly, I think it's a hardware issue.
              My power adapter is 5V at 2.5A, and I don't have heating problems, even overclocking
              airdream Murdock 2 Replies Last reply Reply Quote 0
              • airdream
                @Alberto-Kutran
                it seem you did your best, but unfortunately the RPI3B have it limits, you reached it with N64 emulation. I dont know if a RPI3B+ or a RPI4 improve performance for these games, i guess it does...
                • Murdock
                  Murdock @Alberto.Kutran last edited by Murdock
                  @Alberto-Kutran Your power adapter seams below recommended options, try to use a 3A (this is recommended for pi3/pi4, even more [recommended] when you overclock them !)
                  RPI 3, chargeur 3A, SD sandisk 16go, Disque dur externe Toshiba 1To, nes30Pro
                  • adam0509
                    adam0509 last edited by adam0509
                    • Use a Good Adapter (2.5A at least, 3A recommended)
                    • Disable Rewind for all console
                    • Use PAL roms (they are 50Hz/Fps)
                    • Try Using mupen next (libretro)
                    • Check my video
                    https://www.youtube.com/watch?v=Dr2KyPBDFXc
                    KoCinsKy 1 Reply Last reply Reply Quote 0
                    • KoCinsKy
                      KoCinsKy @adam0509 last edited by
                      @adam0509
                      Thanks!
                      RustyMG 1 Reply Last reply Reply Quote 0
                      • RustyMG
                        RustyMG @KoCinsKy last edited by
                        @KoCinsKy I would ensure that "rewind" is switched off, as this kills the performance on the newer consoles on Recalbox.
                        I do not even use it on my PC Recalbox setup.....
                        Sinclair ZX Spectrum 48k "dead flesh" keyboard, Commodore 64, Amiga A500, Amiga A1200, CD32, PC Engine, PS1, PS2, PSP, Nintendo DS, Dreamcast, Wii, XBox 360, Xbox One-X, Pi2, Pi3, Pi4 owner, ARRM contributor ( http://jujuvincebros.fr/wiki/arrm/doku.php ).
