    "Enhanced Resolution" removed from Pcsx-Rearmed on Recalbox 8.1?
    pcsx-rearmed retroarch psxps1
    7
    14
    5639
    • tekkenism
      tekkenism last edited by tekkenism
      Hi.
      I've just updated to 8.1 version, a great work, thank you all who contributed it!
      Question:
      Is "Enhanced Resolution" mode removed from Pcsx-Rearmed?
      It seems I cannot find it around the options in RetroArch. (Using RPi4)
      But I'm sure, that option was there before the update 8.1.
      Zing jorgemagana 2 Replies Last reply Reply Quote 0
        Zing Global moderator Translator @tekkenism last edited by
        @tekkenism Sorry, but I don't know/never used this option, so I don't know what it's about.
        But, I didn't find it in the documentation, so it shouldn't be available anyway:
        https://wiki.recalbox.com/en/emulators/consoles/playstation-1/libretro-pcsx-rearmed
        • ion
          ion last edited by
          Recalbox 8.1 is 64bit and it use the 64bit version of lr-pcsx-rearmed. The enhanced resolution feature exists only on the 32bit version of the emulator.
          • jorgemagana
            jorgemagana @tekkenism last edited by
            @tekkenism said in "Enhanced Resolution" removed from Pcsx-Rearmed on Recalbox 8.1?:
            Hi.
            Question:
            I have the same question.
              Zing Global moderator Translator @jorgemagana last edited by
              @tekkenism @jorgemagana As I said, I didn't know about this function, but I googled the user information above and it's right:
              PCSX-ReArmed is optimized specifically for 32-bit ARM devices, and "enhanced resolution" option dependent on dynarec support, which is only available on 32-bit ARM, and Recalbox 8.1 is 64bit.
              tekkenism 2 Replies Last reply Reply Quote 0
              • tekkenism
                tekkenism @Zing last edited by
                @zing That was a horrible news.
                • tekkenism
                  Any alternative emulator having the same feature (enhanced resolution) for RPi4?
                    Zing Global moderator Translator @tekkenism last edited by Zing
                    @tekkenism Not sure, check our documentation:
                    • tekkenism
                      @zing So it seems they added it for 64-bit as well?
                      https://github.com/libretro/pcsx_rearmed/issues/690#issuecomment-1250162287
                      Akkeoss 1 Reply Last reply Reply Quote 0
                      • Akkeoss
                        Akkeoss Staff @tekkenism last edited by
                        @tekkenism Hello, I have just done the necessary. The function will be available again in the next version of Recalbox 🙂
                        Site web : https://www.recalbox.com
                        Discord : https://discord.gg/NbQFbGM
                        Twitch : https://twitch.tv/recalbox
                        tekkenism RetroVadus lhari84 4 Replies Last reply Reply Quote 4
                        • tekkenism
                          tekkenism @Akkeoss last edited by tekkenism
                          Hello @akkeoss Great news! Thanks so much for all your efforts!
                          • RetroVadus
                            RetroVadus @Akkeoss last edited by
                            @akkeoss said in "Enhanced Resolution" removed from Pcsx-Rearmed on Recalbox 8.1?:
                            Thank you! 👏 👏 👏 👏
                            Hardware: Raspberry pi 4b (4Gb)
                            Controllers: Connected via GPIO
                            Video: HDMI to RGB (1280x1024, 5:4)
                            • Referenced by  RustyMG RustyMG
                            • lhari84
                              lhari84 @Akkeoss last edited by
                              @Akkeoss Hi, I've updated from RB 8.1.1 to 9.0 an still can't find the option (again). Has there gone something wrong? Thanks
                              Pi 4:
                              Sony DualShock 4 (2nd gen), 8BitDo Pro 2, 8BitDo SF30 PRO, Retroflag SUPERPi 4 Case, Recalbox 9.0
                              Pi Zero 2W:
                              GPi Case 2W, Recalbox 9.0
                              • lhari84
                                @Akkeoss Sorry, posted too quickly. There's a new section "GPU Plugin" in settings, found it there. Thank you very much for the update!
                                Pi 4:
                                Pi Zero 2W:
