    Logitech K380 bluetooth keyboard, Recalbox 8, RPI4
    logitech k380 bluetooth keyboard recalbox rpi4
    2812
    • karlo8321
      karlo8321 last edited by
      Hi,
      Yesterday I've installed the latest recalbox release, but I cannot connect my logitech K380 bluetooth keyboard. When searching for it, it will get found, and also says "connected", but the LED on the keyboard keeps blinking.
      I also do not get any "PIN" or similar to enter on the keyboard (at least on the PC I always need to enter some random PIN when pairing).
      Any advice?
        Zing Global moderator Translator @karlo8321 last edited by
        @karlo8321 Try this:
        https://forum.recalbox.com/topic/24453/how-to-delete-or-clean-reset-all-found-controllers/6
        Does the keyboard have a reset button (it's usually a very small button that you can only press with a clip)?
        karlo8321 1 Reply Last reply Reply Quote 0
        • karlo8321
          karlo8321 @Zing last edited by
          @zing Hi, no it does not have a reset button. The "clean" of all bluetooth is not neccessary as this is the only bluetooth device I have tried to connect. Now i switched off ERTM and then pressed some random keys while "connecting" and it worked. But after each reboot of the pi it is not connected anymore.
          • karlo8321
            I found that also my Xbox One wireless controller is not connecting - seems to be a more global issue for me. Anyone using a rPi4 with its internal bluetooth?
              @karlo8321
              It looks like there really is a bug:
              • https://gitlab.com/recalbox/recalbox/-/issues/2063
              • https://forum.recalbox.com/topic/26286/pi-4-bluetooth-controller-range-issue
              • karlo8321
                Is there any news on this topic so maybe when the bug gets fixed?
                I tried with an external bluetooth dongle and had exaclty the same issue.
                lhari84 1 Reply Last reply Reply Quote 0
                • lhari84
                  lhari84 @karlo8321 last edited by lhari84
                  @karlo8321 To get rid of my BT problem - too low BT range with Pi 4B and/or RB 8 - I've tried 3 different USB BT dongles that worked fine in past with Pi 3B. None of them is working at all with Pi 4B and/or RB 8. Not any bluetooth device is found, as soon I connect one of these dongles.
                  I hope it's just a software issue, as I would prefer using the interneral BT of Pi 4B anyway. I've never had a range issue in the long past, just used BT dongles with Pi3 B (non +) because of the bad latency. With Pi 3B+ everything was fine. I switched to RB 8.0.x in parallel with the switch to Pi 4B, so I can't tell if hardware (Pi 4B) or software (RB 8.0.x) causes the range issue. Anyway, the fact that my USB dongles do not work at all should be caused by software.
                  Pi 4:
                  Sony DualShock 4 (2nd gen), 8BitDo Pro 2, 8BitDo SF30 PRO, Retroflag SUPERPi 4 Case, Recalbox 9.0
                  Pi Zero 2W:
                  GPi Case 2W, Recalbox 9.0
                  • feralshadow
                    feralshadow last edited by
                    Two years later and I am having similar issues with my pi 5 and so if my friend.
                    • csalabs
                      csalabs Banned last edited by
                      Ensure Bluetooth is enabled, forget the Logitech K380 device, then reconnect. Confirm keyboard compatibility with Recalbox. Verify adequate battery power and consider updating the keyboard firmware. Contact Logitech support if issues persist.
                      https://www.linkedin.com/pulse/home-service-app-development-revolutionizing-household-5qkoc/
