    RPi3 and Recalbox 8.0.2 freeze solution.
    rpi3 recalbox 8.0.2 solution
    6
    7
    3542
    • alphay
      alphay last edited by
      I don't know if this is the right way to correct this problem. If someone tries it, he tries it at his own risk.
      In the RECALBOX partition, on the config.txt file, i change the 3 lines of :
      dtoverlay=vc4-kms-v3d
      to be
      dtoverlay=vc4-fkms-v3d
      save the file and restart. I am testing the system two hours now without a freeze so far.
      21stcentury Astur66 2 Replies Last reply Reply Quote 0
      • 21stcentury
        21stcentury @alphay last edited by
        @alphay It doesn't work for me
          Zing Global moderator Translator @21stcentury last edited by
          @21stcentury See if these helps:
          https://forum.recalbox.com/topic/26015/bug-recalbox-8-0-1
          • OmenBoy
            OmenBoy last edited by OmenBoy
            Thank you so much, this seems to have worked for me. I changed all three instances of "dtoverlay=vc4-kms-v3d" to "dtoverlay=vc4-fkms-v3d" and I've gone an hour now with no freezes.
            • Astur66
              Astur66 @alphay last edited by
              @alphay Same problem here with Recalbox 8.0.2 and RBP3B+, no sound at emustation and when you launch a game it gets freezes. So, Is it safe to change dtoverlay to vc4-fkms-v3d? What is this for? I hope that this issue would be solved at next version…
              alphay 1 Reply Last reply Reply Quote 0
              • alphay
                alphay @Astur66 last edited by
                @astur66 It's like your are using an older version of display driver. It is harmless and you can revert back anytime. It is a temporary solution until the developers released a proper fix .
                • lfrank13
                  lfrank13 last edited by
                  O meu Rasberry Pi 3 B+ estava travando quando estrava em um jogo ou quando saio de algum menu. Fiz esse procedimento e até o momento não travou mais. Obrigado pela Dica.
