    Unsolved MAME appears to be broken in Recalbox 8.
    Emulator Arcade/PC/Console
    mame appears broken recalbox
    10
    26
    7663
    • lexx0006
      lexx0006 @RustyMG last edited by
      @rustymg
      Same Problem!
      It's mostly lightgun games, like "Operation Wolf" and so on. I noticed that if I disconnect the "DolphinBar" they work again. I'm back to Recalbox 7.2.2 now, too many bugs in version 8, for example with controllers...
      • RetroVadus
        RetroVadus last edited by
        @RustyMG
        In case it can be useful, I have just opened the following issue. At the end a workaround is commented to be able to work temporarily.
        https://gitlab.com/recalbox/recalbox/-/issues/2219
        Hardware: Raspberry pi 4b (4Gb)
        Controllers: Connected via GPIO
        Video: HDMI to RGB (1280x1024, 5:4)
        RustyMG Zing 2 Replies Last reply Reply Quote 0
        • RustyMG
          RustyMG @RetroVadus last edited by
          @retrovadus Thankyou. Cant believe this wasnt picked up !
          Sinclair ZX Spectrum 48k "dead flesh" keyboard, Commodore 64, Amiga A500, Amiga A1200, CD32, PC Engine, PS1, PS2, PSP, Nintendo DS, Dreamcast, Wii, XBox 360, Xbox One-X, Pi2, Pi3, Pi4 owner, ARRM contributor ( http://jujuvincebros.fr/wiki/arrm/doku.php ).
            Zing Global moderator Translator @RetroVadus last edited by
            @retrovadus I don't have a Lightgun so I can't test it, but in the issue you opened you mention that you have MAME 2003 plus and MAME 2010 ROMS, but do you have them separated into folders with a Configuration override file?
            If not, can you try to do this?
            • https://wiki.recalbox.com/en/advanced-usage/configuration-override
            • https://wiki.recalbox.com/en/advanced-usage/configuration-override#example-1-multiple-versions-of-mame
            • guile64
              guile64 last edited by
              Hi, i've got an issue with the lightgun game house of the dead on Mame, if the lightgun is plugged hotd doest load but if its not plugged the game load, I dont know why?! And im with recalbox 8.1.1 on a raspberry4. Any ideas? Thanks
              luc1anocruz 1 Reply Last reply Reply Quote 0
              • luc1anocruz
                luc1anocruz @guile64 last edited by
                @guile64 it seems that they still haven't solved this problem, not even in this last recent update it had, because my pistol games only open if the dolhpin bar is disconnected, but even if I connect it later, it doesn't work. shot has no effect
                100.2k
