    How Do I Remove System I Don't Care About?
    remove dont care
    6
    12
    8687
    • Guybrush3pwood
      Guybrush3pwood last edited by
      I realize this has been asked a million times, but everything I've found on the topic doesn't match what I have. Some info about my setup:
      Version 8.0-electron
      Connecting to my system with both windows exporer and putty.
      Most solutions state to just delete the roms in the folder, however, I never put any roms in the folder, it's what came preloaded on the system, but when I go into the folder using windows explorer, there's already nothing in the folder except a handful of readme documents. There are already no roms in the folder as far as I can tell. I have hidden items enabled and nada, yet the systems and preloaded roms still show up in Recalbox.
      I tried creating a folder called unused and just cutting and pasting the systems I didn't want into that folder, but upon reboot it just put all the folders back, only this time completely empty, and yet they still show up. I'm not sure what I'm missing here.
      • olivierdroid92
        olivierdroid92 Global moderator @Guybrush3pwood last edited by
        @guybrush3pwood
        Hi, just remove ROM file from the folder , then reboot
        Guybrush3pwood 1 Reply Last reply Reply Quote 0
        • Guybrush3pwood
          Guybrush3pwood @olivierdroid92 last edited by
          @olivierdroid92 See my OP. I did that. There are no roms in the folder. It still shows up.
          • Guybrush3pwood
            Figured it out. There's a setting for hiding preinstalled roms. Enable that and all those systems will vanish.
            • Sammyvee
              Sammyvee last edited by
              Hi Guybrush3pwood, what did you do to fix this exactly? I have been trying to hide unwanted systems for the past week with no luck. I've read all the posts regarding this issue, none help me.
              I have no roms in the ROMS folder to delete, and yet the systems are showing in the menu, and also have the pre-installed games that actually work. Where are these roms coming from? Thanks.
              • Sammyvee
                I just found that there are two locations for the ROMS,
                1. /recalbox/share/roms/<systems>
                and
                1. /recalbox/share_init/roms/<systems>
                So I found where the roms are stored, the question now is how do I delete these unwanted roms? I am using WinSPC to connect to the Recalbox, when I try to delete the roms from /recalbox/share_init/roms/<systems> folder I get the following error message.
                The file is on read-only media, or the media is write protected.
                Error code: 12
                Error message from server (en): Read-only file system
                How do I remove the read only attribute?
                rollbrett Bkg2k 2 Replies Last reply Reply Quote 0
                • rollbrett
                  rollbrett @Sammyvee last edited by
                  @sammyvee
                  You can remount your system as read/write with this command:
                  mount -o remount,rw /
                  SUPERPi CASE-J (new) RPi 3b+ Recalbox
                  MEGAPi CASE RPi 3b Blast16
                  NESPi 4 CASE RPi 4 Recalbox
                  GPi CASE RPi Zero 2 W Recalbox
                  My RetroArchivments
                  rollbrett 1 Reply Last reply Reply Quote 1
                  • rollbrett
                    rollbrett @rollbrett last edited by
                    @rollbrett said in How Do I Remove System I Don't Care About?:
                    @sammyvee
                    You can found this command in the documentation
                    https://wiki.recalbox.com/en/tutorials/system/access/folders-and-ssh-commands
                    My RetroArchivments
                    • Bkg2k
                      Bkg2k Staff @Sammyvee last edited by
                      @sammyvee I wouldn't recommend to modify anything in the read-only system. Next update will reset all the system.
                      RustyMG 1 Reply Last reply Reply Quote 0
                      • RustyMG
                        RustyMG @Bkg2k last edited by RustyMG
                        Unless Im missing something or miss understand your problem, you just select the hide pre installed roms / games option, restart Recalbox, job done.
                        I use this so the "Ports" system doesn't appear on the list of systems available, although if I look on the drive, the folder is still there.
                        Sinclair ZX Spectrum 48k "dead flesh" keyboard, Commodore 64, Amiga A500, Amiga A1200, CD32, PC Engine, PS1, PS2, PSP, Nintendo DS, Dreamcast, Wii, XBox 360, Xbox One-X, Pi2, Pi3, Pi4 owner, ARRM contributor ( http://jujuvincebros.fr/wiki/arrm/doku.php ).
                        rollbrett 1 Reply Last reply Reply Quote 0
                        • rollbrett
                          rollbrett @RustyMG last edited by
                          @rustymg I understood his problem this way, he want not all pre installed games to be hide, only a few ones. and when he use the "Hide" function in the Recalbox Options all of the games are hidden.
                          Or iam totaly wrong, and he do not knew that he can use the "hide" function from the Menu 😁
                          My RetroArchivments
                          Sammyvee 1 Reply Last reply Reply Quote 0
                          • Sammyvee
                            Sammyvee @rollbrett last edited by
                            @rollbrett That is correct. I wanted to only hide some systems and thought the only way to do this is to delete the roms in the system folders I did not want.
                            Thanks to all for helping me out.
