    Cannot use the zero delay usb encoders with RecalBox
    GamePad/GPIO/USB encoder
    recalbox 8 electron usb encoder configuration button
    • XlapatsaS
      XlapatsaS last edited by
      Hi,
      I try to DIY my first arcade console.
      I have already installed RecalBox 8.0 Electron.
      I purchase 2 zero delay usb controllers with joystick and buttons from here:
      The encoder is the same as here (I just put it cause the first link is from a Greek store)
      I cannot configure it with the RecalBox. When I try to configure the controller I cannot skip the buttons I don't use.
      I have the joystick and 6+2 buttons so I have to skip the up+down+left+right and configure the joystick up and left.
      I try to hold a button for skip (as the instructions) but when I push it (and hold it) it doesn't skip it but just add it.
      Is there anyone who used this encoder with RecalBox so can give me tips of how can I make it work.
      Thank you in advance!
      Best Regards
      XlapatsaS
        Zing Global moderator Translator @XlapatsaS last edited by
        @xlapatsas See if this helps:
        https://forum.recalbox.com/topic/25325/problem-with-second-usb-zero-delay-encoder-connection
        • weent19
          weent19 Banned last edited by weent19
          This post is deleted!
